Best Glow Plugs - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-31-2007, 05:16 AM Thread Starter
duct tape & zip ties
bigcountrysg's Avatar
Best Place to get Glow Plugs
Ok where do I get the best price and quality on Glowplugs. I have a 2002 F-250 7.3L and guess what I got 150,000 and I have yet to replace a GPR or a glow plug. But last winter it was starting to have hard cold starts, even with it plugged in. So where should I get my glow plugs from. My GPR is still good. I think 150,000 on Original glowplugs they got to be weak by now. Also do I need to replace the valve cover gasket when I do this.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #2 of 15 Old 08-31-2007, 06:09 AM
Powerstroke Techie
alabamafrog's Avatar
If memory serves me the name and number of the best plugs are the Bosch Durotherm 80033. I got my set of 8 from an internet parts place for $100, sometimes you can catch them on eBay cheaper. I would not use brands like autolite. Some brands have been know to swell up or break off in the heads. You should be able to check resistance at the valve cover plugs to verify bad plugs. If the relay is truly good and the plugs aren’t bad then compression could be the other cold start problem. Either way while I was in there changing the plugs anyway I would take the extra 5 minutes to do a compression test.
“Government, even in its best state, is but a necessary evil; in its worst state, an intolerable one” (T Paine)
Government cannot give anyone anything without stealing it from someone else. (A Frog)
alabamafrog is offline
post #3 of 15 Old 08-31-2007, 06:18 AM Thread Starter
Yeah I understand taking the extra time to do the compression test. But, I really think it is the glow plugs, I don't exactly know the life span of glow plugs. But I think 150,000 miles on the ones that came with the truck. I most likely have a few bad ones. This is not just a cold winter day thing either. This is like if it is 50 degrees out cold hard start. I already checked the GPR with volt meter it is working properly. My problem also did not develope over night either I probablly should have done them last fall. But I thought I would be able to get one more winter out of them. Which I did but barely got started some times. It would take 5-10 tries to get the truck to start. That was even with cycling the glow plugs 3 times prior to starting. Being where I work I can not plug the truck in out in the parking lot.
Another thing I was wondering is Can I have like a 10ft block heater wire. Like can I rewire the block heater so the wire is 10 ft long. I know how will I store that long of a wire. Well I have not got that figured out yet. But I am trying to figure out how to eliminate the need to have an extension cord.
2002 7.3L burnt
post #4 of 15 Old 08-31-2007, 06:20 AM
PSDfan99's Avatar
hey alabamafrog. i was just looking in ur sig..... you got some serious engine work done to your truck huh? must go like a raped ape
Early 99 F-350
4" lift on 33's
Tymar Intake, Isspro Gauges, Modded IDM, HPX, Boost Fooler, 4" Exhaust
-BTS Tranny
-76mm Sledgehammer
-Swamps Tuning
-230cc Casserly Hybrids
-T.E. Modded 17* HPOP
-ARP's, Chromoly's, 910's
-ITP RR
-Jake
PSDfan99 is offline
post #5 of 15 Old 08-31-2007, 06:29 AM Thread Starter
Also if it was a compression problem the engine would run rough, or idle rough until warm. Which is not the case with my problem. But I maybe wrong, I am just going off of my previous experinces working on diesels.
2002 7.3L burnt
post #6 of 15 Old 08-31-2007, 07:32 PM
Bigcountry, We have a lot of T444E (7.3's) at work. They all hard start in the winter. Our International rep. told us that if you have even one bad glowplug the system doesn't work. Something about the glowplugs try to split voltage to make up for the bad one. So just replace the set, replaced the gaskets(150,000 miles) and run'er some more.
BaggerMatt is offline
post #7 of 15 Old 08-31-2007, 07:41 PM
Beer Drinker/Ballast Guy
clmtng's Avatar
I had that hard start thing going for about 3 months. 50+ degrees and I still had to plug it in to even get it to start. I changed my plugs...Napa for about 100 bucks. That did nothing to help it. Changed my GPC and it started right up, haven't had an issue since...but winter's coming soon. As for the gaskets...I bought mine, they are alot more than I thought, but I didn't have to change em. The connections were good and no cracks or anything in the old ones. I'd buy them just in case, then return them if you don't need em. Good luck and keep us posted.
99.5 F-250; Garrett GTP38BB Turbo; 4" MBRP Exhaust; 2" Leveling Kit; AEM Air intake; ZooDad Mod; Foil Delete; AutoMeter Z series gauges, pyro, boost, trans. temp w/piller pod, muffler delete, Tunes by Tony Wildman; Recon tail lights and third brake light; Headlights from Raul; Twinkle mod // Soon to be: winch
clmtng is offline
post #8 of 15 Old 08-31-2007, 07:42 PM
Desert Shield/Storm Vet
vitalidle's Avatar
Hey BC Im not sure what you think of sythetic oil, but made a huge difference for me last winter. I am using the Rotella.
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #9 of 15 Old 09-01-2007, 08:39 PM
99 Red Stroker's Avatar
Thumbs up Hi Big Country
I had the same thing going last winter. This spring I changed mine. I got a kit from Powerstrokeshop.com. It came with motorcraft plugs, wire harnesses,and valve cover gaskets. Everything in mine looked good. But with 150,000 on mine I just replaced it all. I haven't been in the cold since the work was done. Hope I'm good to go now HA!!! I did have two bad plugs. Just give them a call and they will fix you up. Fair prices and they know 7,3's. Check out their web site there is an 800 number. Hope this helps-- as we all know winter is coming.
99 Red Stroker
99 Red Stroker is offline
post #10 of 15 Old 09-02-2007, 09:19 AM
Dieselis' Maximus
driximus's Avatar
I read somewhere that cycling the glowplugs wasnt good for them. And that if you just wait even when the WTS light goes off the plugs are still heating. can anyone else confirm this? I did this last winter and it worked out pretty well no hard starts.
"Why in hell can't the Army do it if
the Marines can. They are the same
kind of men; why can't they be like
Marines."
Gen. John J "Black Jack" Pershing, USA; 12 February
1918
driximus is offline
