HELP TRUCK DOWN - Ford Powerstroke Diesel Forum
Old 11-07-2011, 07:58 AM
HELP TRUCK DOWN
Well i have a 01 F350 dually with 237k miles that was running fine till this morning, started truck up and white smoke galore, then proceeded to leave neighborhood and touch the throttle and black smoke everywhere, no power, funky idle,,,,no check engine light . its at neighborhood shop and they said something about EGR....? Does this truck have one since it has no emissions, i did notice coolant was low when i had hood up. I was thinking that metal hose from turbo pedastal ....truck has a 4 pos chip and wife said sat it wouldnt boost past 10 lbs ......? ANY IDEAS
Old 11-07-2011, 08:28 AM
no egr cooler on 7.3L you may have bad turbo or injector - usually grey/white and black smoke is over fueling one of the injectors may also be bad
Old 11-07-2011, 09:21 AM
change your fuel filter, and yes no egr. If it was me and a shop said anything about an egr in a 7.3 id get as far away from that shop that I can
Old 11-07-2011, 09:24 AM
Just out of curiosity I googled ford f350 egr tube with 7.3 and a frigging part number came up. I am so confused .
Old 11-07-2011, 04:21 PM
There is an exhaust back pressure sensor on a tube.. thats about it... no 7.3 ever had egr, guaranteed.
Old 11-07-2011, 05:03 PM
Your truck DOES NOT have an EGR. Take it to a different shop who knows stuff about the 7.3.
Old 11-09-2011, 04:04 AM
Any updates?
Sent from my DROID X2 using AutoGuide App
Old 11-09-2011, 08:56 AM
ok .....so far its running again, replaced the fuel pump on frame[? didnt know it was bad but ok], truck runs fine, tested for blown head gaskets ....nope, no boot leaks or check engine lights.......topped of coolant and will drive around but seems to be fine........frankly i am confused but I have the big ***** back .
Old 11-09-2011, 09:06 AM
I had mine go out last year but smoke for low fuel pressure is blue. Wouldnt boost or wouldnt go over 10 mph. When you were describing it in first post it all seemed like fuel pump except for the black smoke.
Old 11-09-2011, 09:24 AM
Blue.....black ....it was dark and hard to see......will drive it around and see if any issues come back
