hi beams - not working
i have an issue with my hi beams they both quit working at the same time when i flip my lights on the low beams work fine when i flip to hi beams i loose the headlights i dont have the owners manual for the truck so i dont know what fuses and relays are for the headlights i am thinking it is a fuse or relay that failed any one else have the same problem???
any help is appreciated thanks everyone |
You should be able to look up online what fuse and or relay that might be. It may also be the multifunction switch itself.
im kinda thinking it may be the switch or a wire i brought in the shop the other nite n checked all the fuses and swapped relays and i coulndt find any that were bad i guess sometime i will have to look into the switch - i need to change out my starter switch on the column anyways so
