Oil question on my 7.3 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-05-2011, 06:45 AM Thread Starter
adavis11's Avatar
I have a 99 7.3 powerstroke. I went to check the oil today and noticed that I am about 2 quarts low which puts me at the add line. I have run about 4500 miles on this oil change without adding any oil. I was just wondering if this type of oil consumption is normal?
adavis11 is offline
post #2 of 11 Old 11-05-2011, 09:31 AM
Zaairman's Avatar
Quoted: 12 Post(s)
You sure its not leaking any? That is usually a more common issue...
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 11 Old 11-05-2011, 09:41 AM
JEL
If you aren't leaking any, then that does seem a little bit high. It could just be something like injector O-rings.
JEL is offline
post #4 of 11 Old 11-05-2011, 09:48 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Any motor isn't designed to use oil. So it's either burning it or leaking it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 11 Old 11-06-2011, 08:48 AM
ScottyP5947's Avatar
Quoted: 2 Post(s)
I use just about that much too - 2 quarts in 5,000 miles. I agree, it shouldn't be using any at all but that's not too bad, IMO. Mine does not leak at all. Not a drop. Gotta love that!
SCott
2000 XLT F-250 7.3 Crew Cab Auto w/Transgo shift kit
Zoodad
4" MBRP turbo back exhaust w/muffler
PHP TS chip - 65 tow/80DD/120 race
Stancor relay
Caterpillar ELC coolant
Broken-into door lock mod
6637 filter
285/75/16 Hankook ATM's
2" Rough Country add a leafs all around
In the Driveway:
2000
, chipped! (For the wife)
1995 Ford Mustang 3.8 (
2012 Dodge CCSB 2500 w/Hemi
ScottyP5947 is offline
post #6 of 11 Old 11-06-2011, 09:32 AM
Powerstroke Junkie
NCHornet's Avatar
Ford consider anything less than 1 quart per 1K is totally normal. I didn't say that I do. But a couple quarts in 4500 could have several reasons. I wouln't add 2 quarts, I would simply do an oil change and keep on trucking. 2 Quarts low is nothing on a vehicle that holds as much as these.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #7 of 11 Old 11-06-2011, 09:57 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
I run about 5k intervals on the Rotella t6 synthetic, and Its exactly where I left it when i put it in
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #8 of 11 Old 11-06-2011, 10:18 AM
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
All in all 2 quarts isn't a ton over 4.5k. Where you towing a lot over that span? I would check for leaks and if you don't find any just watch the oil levels...
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #9 of 11 Old 11-06-2011, 07:15 PM Thread Starter
adavis11's Avatar
I ended up doing an oil change instead of adding oil. I switched it over from motorcraft deisel oil 15w40, to rotella t-6 syn. So I will keep an eye on it and see what happens. And yes I tow almost every day. I have a landscape company and am pulling mowers and my bobcat at least 3 days out of the week, so I dont know if that has anything to do with it or not. Thanks for all the input!
adavis11 is offline
post #10 of 11 Old 11-06-2011, 08:55 PM
atvrider93's Avatar
Quoted: 8 Post(s)
my truck probably leaks 2-3qts over 5Kmi. I should probably fix that.
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
