First go at this PS stuff... - Ford Powerstroke Diesel Forum
post #1 of 21 Old 11-04-2011, 08:54 PM Thread Starter
Bought my first Powerstroke 2 days ago, and have been doing some serious digging on here and on the truck to get a grasp of what all is going on... only mod that I can visibly see is that the stock muffler was cut off and a piece of pipe added in.
- First thing I've noticed is that it runs great and smooth, but still lacks some "oomph" down low. The truck cranks and runs great at ~40 degree weather in the mornings. I had both batteries load tested, along with the alternator and all checked out great. The turbo really comes on around 2k rpms, but I feel that it is still lacking compared to friends trucks I've ridden in.
- Changed the fuel filter and air filter today. The fuel bowl was nice and clean. The stock airbox is still in tact, and there was enough loose dirt in the box that I went ahead and took my shop vac and cleaned it out, to hold me over until I can get the big filter conversion done.
- I had to add about a half quart of diff fluid to the front and rear diffs.
- The power steering pump is whining at me, which after checking it was a touch low on fluid. I filled it to the fill line and it is still whining, although not as loud. Guess I need to go ahead and replace the pump? Don't want to lose the brakes when it does decide to peace it
- Do the F250s come with greaseable ball joints and tie rod ends? I know that my F150 did not, so I'm trying to figure out if these have been replaced?
- Lastly, back to the first part about the power loss... on the ride home from purchase, it was about 120 miles of highway. With the cruise set on 73, the overhead display read 15.5, which I am figuring to actually be less. After going over the engine bay, there is not any soot on the firewall to show a boost leak there, BUT there is a significant amount of residue/buildup on the cold side pipe where it runs into the boot for the intercooler. Reading around on here, I'm guessing that replacing the boot there with new clamps may bring it back to life and pull the MPG's back up?
I'm open to any and all suggestions/tips to point me in a good direction. I'm loving it so far, and looking forward to many many miles of fun
slowridin03 is offline
post #2 of 21 Old 11-05-2011, 03:55 AM
Toms01PSD's Avatar
Quoted: 64 Post(s)
Congrats on the new truck. As for a boost leak, does it have the orange boots going from the intake spider to the heads? They are the stock boots. If so, take a screw driver and see if they are loose. I would replace them depending on their condition. I bought new ones when I had to do some stuff on my truck and I couldn't believe how loose those boots were. I could have loosened the band clamps by hand. I'm running through my first tank of fuel since fixing it so i'll see if my mileage increased or not.
Tom
2001 F250 7.3 auto 4x4 Lariat CCSB
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
ISSPRO Boost, Pyro, and Trans Gauges
Strictly Diesel Pre-Pump Filter/In-Tank Kit
Strictly Diesel Regulated Return and Fuel Bowl Delete
High Flow Banjo Bolts
Nitto AT's 305/70R16
2009 Pontiac G8 GT
Intake, Exhaust, Tune
Camaro 20's, Camaro SS Brembo's
1997 VDub Passat GLX VR6
Toms01PSD is offline
post #3 of 21 Old 11-05-2011, 06:32 AM Thread Starter
No orange, but blue... Others are black and are what feel saturated. Looks like I need to replace them for sure. Is that correct clamp connecting to the turbo?
'03 F250 CCSB w/ 7.3
6637 Filter
CCV Mod
stock muffler delete
post #4 of 21 Old 11-05-2011, 08:49 AM
Quoted: 14 Post(s)
Yes, that's the correct clamp. I thought the same thing and thought it should have been one of the t-bolt type clamps, but that is indeed the OEM clamp. It has v-channels welded inside, and sucks the two flanges up tight when you tighten the clamp.
Without telling us more about your buddies rig, it's hard to say if anything is actually wrong with your truck. If he has a chip or something in his, it will obviously run differently than yours. Make sure you're comparing apples to apples :-)
ttyR2 is offline
post #5 of 21 Old 11-05-2011, 09:25 AM
Quoted: 3 Post(s)
I didn't have any soot on the firewall either, but when I crawled under the truck with a flashlight there was soot lines on the passenger side up pipe. When I took it apart it fell off the collector without even loosening the boolts, so still might have an exhaust leak.
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #6 of 21 Old 11-05-2011, 02:58 PM
Flatbedcowboy's Avatar
Quoted: 15 Post(s)
its weird that putting the NAPA 6637 filter on your truck can make it feel different in low end power. After cleaning the boots off and replacing with the big filter I noticed in seconds the differnce, so if you buddies got the filter then that could help.
Or maybe his foot is heavier?
Mike
E99 F350 XLT 7.3L, Extended Cab, 4x4, Dually, Auto Trans, Custom Flatbed
DIY Intake, 17* HPOP, 4" Straight-Pipe, Stancore Relay, Signal/Heated Mirrors, Fog Lights
WildCountry XTX Sports
Flatbedcowboy is offline
post #7 of 21 Old 11-05-2011, 04:21 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Without any mods, it isn't very good at the low end. Just they way they are. My turbo starts to light at about 1500RPMs, but I've got a DIY intake. You did have the batts checked individually, correct? Otherwise, you won't get a good reading.
The PS pump takes ATF, so a lot of people flush it out and use some synthetic ATF, and I did and it did help my whining.
Tie rods, yes. One on the pitman arm too I think. Ball joints, nope.
15.5 might be close. What kind of gearing is in it, do you know? I'd do the CCV mod, and clean up all the boots and intercooler good or replace the boots and that could add maybe a pound or so.
replied in red
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 21 Old 11-05-2011, 07:39 PM
Toms01PSD's Avatar
Quoted: 64 Post(s)
I was referring to the boots that are under those boots on either side going to the heads. If they aren't orange then they've been replaced before. Climb up on the engine and look behind that blue boot and the black boot on the other side.
Tom
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
2009 Pontiac G8 GT
post #9 of 21 Old 11-05-2011, 08:14 PM Thread Starter
My apologies... his is an 03 F350. Only difference is his has the big filter mod and full 4" Magnaflow exhaust and 4.10s vs. my 3.73s. He is getting 18-20 hwy unloaded and 14 pulling an enclosed trailer with a car inside.
I will certainly check that tomorrow in daylight and get back on that
I let him drive it too, as all I had to go on was the passenger seat feel of the pants... he agreed with me. As stated above, he has a few more mods than I do with 4.10s
Originally Posted by jesilvas View Post
replied in red
Both batteries were checked individually..., I used synthetic ATF as recommended on several threads here, still whining, but not as loud. 3.73 gears according to the tag on the rear diff
Gotcha, I will check it first thing tomorrow and report back
6637 Filter
CCV Mod
post #10 of 21 Old 11-06-2011, 06:31 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Not calling him a liar, but there is no way he's getting 18-20mpgs with 4.10s unless he's doing 55 everywhere. Yea I got a dually, but I only get about 16 with the same mods.
4R100, 2wd
330,000 + miles
jesilvas is offline
