hidden oil leak - Ford Powerstroke Diesel Forum
post #1 of 4 Old 11-04-2011, 01:39 PM Thread Starter
hidden oil leak
Well I got this truck a few months ago. Its a 2000 f250 7.3 and noticed it had a bad oil leak. The guy dragged this truck when he had it. I looked to see where it was coming from and found out that it was all over the underside of my truck. It starts somewhere below the manifold . I'm hoping its not the head gasket But I think it is. Its all over the front end and frame but I cant pinpoint it. Do these 7.3 have a lot of problems with head gaskets? Could it be a Hi pressure hose thats spraying. I'm new to deisels so any advise would be great. thanks It leaks prolly a quart every two weeks.
snopushing powerstroke is offline
post #2 of 4 Old 11-04-2011, 02:06 PM
Zaairman's Avatar
Quoted: 12 Post(s)
I'll take oil cooler for $500, Trebek.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #3 of 4 Old 11-04-2011, 07:51 PM
Toms01PSD's Avatar
Quoted: 64 Post(s)
Ding ding ding! Oil cooler is right behind the manifold on the drivers side.
Tom
2001 F250 7.3 auto 4x4 Lariat CCSB
6637 intake
4" MBRP exhaust
PHP tunes
Foil delete
EBPV delete
ISSPRO Boost, Pyro, and Trans Gauges
Strictly Diesel Pre-Pump Filter/In-Tank Kit
Strictly Diesel Regulated Return and Fuel Bowl Delete
High Flow Banjo Bolts
Nitto AT's 305/70R16
2009 Pontiac G8 GT
Intake, Exhaust, Tune
Camaro 20's, Camaro SS Brembo's
2014 Chevy SS
Holden Badges, Intake, Exhaust, Coilovers, VMR 710's
Toms01PSD is offline
post #4 of 4 Old 11-06-2011, 09:38 AM
Powerstroke Junkie
NCHornet's Avatar
Yes the HPOP lines are known to leak on the 7.3, much more thasn the oil pump itself, which you have two on the front, a high and low pressure pump. You need to start with a good cleaning with your favorite degreaser. The oil lines have a O ring at the connector and these are known to fail and can spray oil everywhere or just drip. A mirror on a stick and a good maglight is your friend here.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
