Expected Behavior? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 11-03-2011, 01:57 PM Thread Starter
Silvercrew's Avatar
Expected Behavior?
Hey all, I finally have my 7.3 running great and now have a question. I have noticed that when coasting downhill with my foot completely removed from the throttle my rig occasionally sounds like an old big block with a big ol' cam in it. Kind of sounds all lopey and if I blip the throttle it responds perfectly and does not shake while doing this and get no SES light or anything. Is this an expected behavior? Thanks!!
Nick
Silvercrew is offline
post #2 of 16 Old 11-03-2011, 02:07 PM
do you have overdrive disabled when you hear it - around 35 - 40 mph?
mine does it too. I think it's the transmission (maybe torque converter) doing a little engine breaking. I don't think it's anything to worry about.
Try it with overdrive enabled - see if it goes away.
01 7.3 f350 CC/SB - chipless w/3:73s
TrueCool Transcooler
FTVB
Gauges
AIS
Walker BTM
Bilstien 5100s
Soft top
daveyburt is offline
post #3 of 16 Old 11-03-2011, 02:09 PM Thread Starter
Silvercrew's Avatar
Today it was with OD enabled but I was only doing about 30 or so, so the transmission had not shifted up to 5th yet. In the past I have noticed it with OD off as well.
2001 F350 7.3l 4x4
PHP Phoenix 6-Pos Chip, Straight Pipe, Stancor GPR, 6637 DIY Intake, Triple gauges, Coolant Filter, RiffRaff Boots
post #4 of 16 Old 11-03-2011, 02:22 PM
Zaairman's Avatar
Quoted: 12 Post(s)
While coasting down a hill, your injectors will actually stop firing sometimes. It's probably just them going off and on.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust
, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
Zaairman is offline
post #5 of 16 Old 11-03-2011, 04:10 PM
revolvingsteel's Avatar
Mine does this only sometimes when shifting from OD(4th) to 3rd gear.
Early 99 F250, Tuned by Gearhead, Diamond Eye 5", DIY intake, GS EGT/Trans/Boost, FRX, HPX, CCV, Schaeffers 9000, ELF7405, Stancor
Next: A Better Trans Cooler, 35"s
revolvingsteel is offline
post #6 of 16 Old 11-03-2011, 07:27 PM
Galaxie's Avatar
Yea, you are inbetween the injectors shutting off and on.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #7 of 16 Old 11-03-2011, 10:51 PM
Yup, normal.. cool noise when they do that aint it? lol
Dietoremain is offline
post #8 of 16 Old 11-04-2011, 04:29 PM
Galaxie's Avatar
Sure is! My 6.0 it is on then off clear as day. The 7.3, you can hear it going back and forth. Sounds bad ***.
Well, not as good as my 312 Fairlane popping down hill but whatever.
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #9 of 16 Old 11-07-2011, 05:03 PM Thread Starter
Silvercrew's Avatar
Yes, sounds very cool (now that i know what it is). This will in now way harm the engine, will it? It seems to happen everyday on the same hill every morning. Thanks for the clarification too. This place is awesome!!
2001 F350 7.3l 4x4
post #10 of 16 Old 11-07-2011, 05:08 PM
Zaairman's Avatar
Quoted: 12 Post(s)
It's totally normal, nothing to worry about.
Zach
SLAPS Member #153
Zaairman is offline
