Wheel Spacers - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-02-2011, 05:21 PM Thread Starter
99BEIGEPOWERSTROKE's Avatar
Wheel Spacers
I have moto metal 951 wheels 16x9 I run in summer with 315/75/16 tires and have no rubbing but in the winter I run stock 16x7 wheels with 315/75/16 tires and they rub on leaf springs. Will wheel spacers solve this problem with stock wheels? Are wheel spacers bad to run?
Thanks
1999.5 FORD F250 SUPERDUTY 4X4 EXT CAB
7.3L POWERSTROKE DIESEL
6 SPEED
SWAMPS 175/146 SINGLE SHOT INJECTORS
SWAMPS TUNING
6" AUSSIE STACKS
AFE INTAKE W/ PRO GUARD 7 FILTER
VAN TURBO
4" SUSPENSION LIFT
315/75/16 BUCKSHOT MAXXIS MUDDER TIRES ON STOCK WHEELS (WINTER TIRES)
16X9 MOTO METAL 951 BLACK WHEELS (SUMMER)
COWL HOOD
99BEIGEPOWERSTROKE is offline
post #2 of 7 Old 11-02-2011, 05:55 PM
Quoted: 14 Post(s)
Wheel spacers on anything that can haul a heavy load like these trucks is bad news. Don't do it.
ttyR2 is offline
post #3 of 7 Old 11-03-2011, 04:57 AM Thread Starter
Bump.......
6 SPEED
SWAMPS TUNING
6" AUSSIE STACKS
VAN TURBO
4" SUSPENSION LIFT
COWL HOOD
post #4 of 7 Old 11-03-2011, 06:01 AM
I have always read that wheel-spacers are fine as long as the center of the tire's contact patch remains in the same location as stock. It has to do with leverage and how forces are applied to the suspension. Heck, the duallies have about a 5" spacer on the front hubs to allow them to use the same wheel's front and back.
BigA
Diesel Noob
2000 F-350 CCLB 4x4 Dually "Princess Dixie"
biga is offline
post #5 of 7 Old 11-03-2011, 06:15 AM
Bend6.0's Avatar
I ran 2" spacers on my '99 to keep my 37's from rubbing the springs. I had that truck for 3 years with no negative outcome of running the spacers. I also towed the toyhauler often with no issues. The spacers will keep you from rubbing the springs and solve that problem. And since you have run those tires on the wider rim already you shouldn't have any fender rubbing issues either. Maybe you can get away w/spacers smaller than 2" which would be nice.
'03 F350 CCSB 27k
6spd,SCT Livewire
285/75/16 +2"front
RCD EGR Delete,AEM Intake
Sold:
'06 F350 CCSB 87K
6spd 4x4manual hubs
6"Fabtech w/35"s
'01 Stroke CCSB 112k 6spd
5" lift, 35" tires 4" straight
NAPA 6637 Intake, Wicked Wheel
TS T6 Pyro/Boost Gauges
AIH/EBPV Delete
2005 6.0, 2001 7.3, 2-'99, '97,'96,'95,'92IDI, 3-Cummins
Bend6.0 is offline
post #6 of 7 Old 11-03-2011, 05:19 PM Thread Starter
Ok thanks for the help...
6 SPEED
SWAMPS TUNING
6" AUSSIE STACKS
VAN TURBO
4" SUSPENSION LIFT
COWL HOOD
post #7 of 7 Old 11-03-2011, 05:29 PM
Spacers are bad news. Sorry.
2004 F-250, ZF-6, 03 turbo 4" mbrp exh. PHP reprogrammed FICM, sct X3, egr delete, auto meter ultra lite boost & pyro, arp head studs, firestone destination m/t's. ccv mod, mag hytec diff covers, 35% tint, dieselsite coolant filter, cat elc, B&W gooseneck hitch.
screamin7.3 is offline
