Long term storage
Hey guys! I have a couple questions regarding our trucks. Im going on my mission and my truck is going to almost be sitting for 2 years. My dad plans on taking the truck out once a month around the farm. But thats it. What should i do in terms of fuel and other things? Does diesel fuel go bad like gas? Thanks
Another member posted this awhile back. It's from Ford and is guidelines on vehicle storage.
NEW VEHICLE STORAGE GUIDELINES Page 221 DESIGN GENERAL • Store vehicles in a dry, ventilated place; protect from sunlight if possible. • If vehicles are stored outside, provide regular maintenance against rust and damage. BODY • Wash vehicle thoroughly to remove dirt, grease, oil, tar, or mud from exterior surfaces, rear wheel housing, and underside of front fender. • Periodically wash vehicles stored in exposed locations. • Touch up exposed raw or primed metal to provide rust protection. • Cover chrome and stainless steel parts with a thick coat of auto wax to prevent discoloration. Rewax as necessary when the vehicle is washed. • Lubricate all hoods, door hinges and latches with a light grade oil. CAUTION: Keep all rubber parts free from oil and solvents. • Cover the interior soft trim to prevent fading, if stored in exposed location. ENGINE • Start the engine every 15 days and move the vehicle at least 25 feet. Run it al fast idle until it reaches normal operating temperature. • Shift the transmission into all gears while engine is running at idle speed. FUEL SYSTEM • Regularly move vehicles short distances to mix fuel anti-oxidation agents. NOTE: During extended periods, if vehicle is stored for 60 days or more, gasoline may deteriorate due to oxidation. This can damage rubbers and other polymers in the fuel systems such as fuel pressure regulator diaphragms and fuel line connector seals. It may also clog small orifices. Diesel fuel deterioration in the form of fuel separation, sludge formation, and bacterial growth can cause restrictions in fuel supply lines, filters and sticking of fuel injection systems components. A commercially available gasoline fuel stabilizer (“Sta- Bil” or equivalent) should be added to gasoline-powered vehicles or a diesel fuel stabilizer (“Fire Prep 100” or equivalent) to diesel-powered vehicles whenever actual or expected storage periods exceed 60 days. The manufacturer’s instructions packaged with product should be followed. The vehicles should then be operated at an idle speed to circulate the additive throughout the fuel system. A volatile, corrosion inhibitor (NOx Rust VCI 105" or equivalent) added to the fuel will protect the fuel tank inner surface from corrosion. Follow instructions packaged with product. COOLING SYSTEM • Maintain appropriate antifreeze protection against freezing temperatures. • Only use coolant as recommended in your vehicle owners manual. BATTERY • Check and recharge as necessary. • Keep connections clean and covered with light coat of grease. BRAKES • Make sure brakes and the parking brake are fully released. TIRES • Maintain recommended air pressures. MISCELLANEOUS • Verify that all linkages, cables, clevis pins, and levers under the vehicle are covered with grease to prevent rust. • Move trucks at least 25 feet every 15 days to lubricate working parts and prevent corrosion. TRANSMISSION • Run engine to normal operating temperature. • Shift the transmission into all gears with engine running at idle speed. • Check fluid level and condition (no water contamination, etc.). • Stripped Chassis vehicles – cover transmission to prevent water from entering through |
if you want an easy way to heat up your transmission (like it says above) w/out having to drive the truck, throw the truck in gear and throw in the x-fer case in neutral.
Its also a great way to head things up in really cold weather. |
Sent from my iPhone using Autoguide |
