O/D button not working.... can i disconnect? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-29-2007, 02:10 PM Thread Starter
I am having some bugs with my truck, and i think it has something to do with my overdrive button (the cables that go to the shifter).....
can i just disconnect it? any harm in that?
The truck wont have any load on it, so i wont have to drop it out of O/D.....
or will disconnecting the switch cause the truck to go into some sort of limp mode?
Thanks in advance
-Victor
CheM is offline
post #2 of 6 Old 08-29-2007, 06:25 PM
keystone crawler's Avatar
i don't know if want to replace it but i had a same problem however i use OD on/ off buttom got once from the dealer like 60 buxs if remember takes about 2 mins to change out too .
99 PSD F250 DD / toy hauler
94 YJ 2.5 slow and not street legal anymore
keystone crawler is offline
post #3 of 6 Old 08-30-2007, 11:26 AM Thread Starter
well i will replace it, but i want to make sure its the problem first before i throw money on it =).
anyone know if i can just disconnect it?
CheM is offline
post #4 of 6 Old 08-30-2007, 04:11 PM
i found a tsb on that because what happens is there in angel hair wires in there that get a internal break and then dead in water . everything was fine just couldn't mannual turn off OD when i wanted too
post #5 of 6 Old 09-12-2007, 04:03 PM
yep- replaced mine tonight super easy and works as should now-
Dependng on production date you may get the whole shift lever with switch and harnessMine happened to fall into that category as I was expecting to get button only and have to fish harness in levermine cost less than 40 bux..
Regards, Scott
08 F350 6.4L 4x4 SRW FX4 CrewCab
groovey1 is offline
post #6 of 6 Old 12-15-2008, 11:42 PM
wrs8574's Avatar
Send a message via AIM to wrs8574
I'm having this exact problem now as I type. I just had a world class 4R100 builder do a stage II build and told him about the OD button basically becoming inert. His thoughts were to replace the entire shifter handle. I already replaced the OD endcap button with zero results.
So basically changing out the entire shifter assembly is easy and fairly cheap correct?
PLEASE IF YOU OR SOMEONE YOU'VE EVER LOVED HAS HAD ANY FORM OF CANCER, DONATE TO YOUR LOCAL AREA CANCER RESEARCH FACILITY. THANK YOU FOR ALL BEING IN MY CORNER THROUGHOUT THIS FIGHT MY FIANCE' IS FIGHTING. WE WILL WIN!!
FAILURE IS NOT AN OPTION.
wrs8574 is offline
