Fluid drain - Ford Powerstroke Diesel Forum
Old 10-28-2011, 08:03 PM
Fluid drain
So I have water as my coolant right now an I need to get anti freeze in it because it's finally getting cold here. Is there a was to drain my radiator fluid so I can put anti-freeze in it?
Old 10-28-2011, 08:17 PM
Winning DUHHH
Should be a pet**** on the bottom corner
Old 10-29-2011, 02:55 PM
A pet what where?
Old 10-29-2011, 02:57 PM
on the radiator on the driverside there is a drain valve. And if you want to get most of the rest take off the lower hose on the passenger side.
Old 10-31-2011, 12:28 PM
Send a message via AIM to rufushusky
Here is the drain valve:
And if you remove this blocks you can get 6-7 gallons out...
