am i an Idiot? ( AC/Heater control question) - Ford Powerstroke Diesel Forum
Old 10-22-2011, 07:58 AM
Ok. So i just purchased a 2001 excursion.
I cant for the life of me figure out how to use the ac/heater controls. In my previous vehicle i clicked a button to turn on the ac unless it was on defrost setring then it turned on by itself. In the excursion the only way i can seem to keep the ac from turning on is by having it on the upper vent setting. any other setting i put it on seems to blow colder air than ambient. Is this right? how do i get the ac to not run and just have ambient air blow on my feet and face at the same time?
Thank in advance..
Old 10-22-2011, 02:59 PM
NOT a Democrat
Yes you are an idiot. JUST KIDDING. Right to the left of off you should have a vent only. Unless you are a Lariat then you have digital.
What truck you do have?
BTW, BAD *** cars in the esig man!
Old 10-22-2011, 03:28 PM
Feedback Score: 5 reviews
Possibly, but I don't think it's related to your problem.
I can't remember the temp, but basically the air compressor will always be on in "vent" mode unless ambient temp is below a certain temp... I want to say 60*, but I can't remember.
Can't help with your other issues, tho.
Old 10-22-2011, 03:32 PM
NOT a Democrat
I wish I wasnt drunk, I could probably actually help!
Old 10-22-2011, 03:35 PM
I wish I was drunk. But I still can't help.
Old 10-22-2011, 03:39 PM
The Tamed Racing Driver
Get a thermometer on it to make sure. The A/C should only be on with it in A/C or A/C MAX setting and sometimes in defrost for dehumidification purposes.
Old 10-22-2011, 03:43 PM
Thanks guys lol. I thought it should only be on in ac or max ac. But it's on all the time in at of the vent positions except just to the left of off.
Old 10-22-2011, 03:46 PM
Gslaxie, thanks. Wish they were mine. I just take, the pics.
Old 10-22-2011, 06:02 PM
Not quite... in newer Fords (such as our Super Duties), the AC is on when the vents are in the face/floor selection...sometimes. The AC isn't supposed to come on in that position if the temp is below 50, or so. The only position when the Ac is NOT supposed to be on is when it's on the vent or floor selection.
And since you're in St. Louis...
http://www.stlouisareapowerstrokes.com/
Old 10-22-2011, 09:04 PM
Thanks Zach, ill check it out. Do you guys ever have meets? / install days?
