no start possibly fried computer plz help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-19-2011, 04:09 PM Thread Starter
killa071's Avatar
its a 2002 f250 7.3 auto trans the truck had a hard time starting so the owner changed the relay for the glow plugs with a starter relay well he hooked it up but forgot one of the small wires on top well truck fired up like perfect so he shut key off the truck stayed running it ran for about a minute then died and no start after that so i came to look at the truck well when it cranks the tach don't move so changed the cps 2 times still nothing changed relays with correct one and it won't power up i have 2 codes they are p0380 p1670 please help u can call me to i need the truck fixed 1-218-969-9335
2011 F350
mobile 1 5-40
killa071 is offline
post #2 of 5 Old 10-26-2011, 12:55 AM Thread Starter
killa071's Avatar
Bump anyone
2011 F350
mobile 1 5-40
killa071 is offline
post #3 of 5 Old 10-26-2011, 12:44 PM
STLstroker's Avatar
I can't find any of those codes in my Haynes manual. Ill give you a bump though man. Sorry
Luke
99 F-350 7.3 turbo diesel ext cab 4x4
All terrain tires
Hypertech Power Programmer III
Hurculiner on entire bed
Tonneau cover
fog lights
4" Straight turbo back exhaust
DIY Tymar Intake
wastegate delete
ISSPRO triple pod guages
Much more wanted but $ plays a big factor in college
STLstroker is offline
post #4 of 5 Old 10-26-2011, 12:57 PM
Feedback Score: 5 reviews
P0380{2}
GP Relay Output Circuit Fault
P0380{3}
GP Circuit Malfunction
P1670{3}
IDM Electronic Feedback
ToMang07 is offline
post #5 of 5 Old 10-26-2011, 12:58 PM
Did he check all the fuses? Does the WTS light come on/off like normal?
Sounds like the IDM might be fried. Definately need to fix the GPR and wires, too.
Also, on the 02/03 the tach will not move when you crank it, so it's not the CPS, make sure it still has a Ford or International CPS in it.
ToMang07 is offline
