Leveling - Ford Powerstroke Diesel Forum
Old 10-17-2011, 07:03 PM
Leveling
Was looking at leveling kits, but here on the forum i read something about filpping the shackles? Does this level the front end of your truck? If si what do you need to do this?
Old 10-18-2011, 09:19 AM
usually flipped shacles is on the rear of a truck. on Jeeps with leaf springs you can reverse the front shackles which will give you a little better entry angle, which i suppose you could do on these trucks but i dont thing the way they are set up will allow it. most people replace their shackles.
Jim
Old 10-18-2011, 12:38 PM
In your sig it says you've been leveled. How much was the kit? Or what'd you do?
Old 10-18-2011, 05:09 PM
I did a 2.5in Pro Comp shackle kit I bought from Cowboy diesel I believe it was like $200 +/-. almost all of the venders that are on here carry the kit. I also went with a set of bilstein shocks. Yet to come will be F350 rear blocks and and adjustable track bar. the kit came with track bar spacers that work OK but i may go with an 1.5in add a leaf eventually and ill need the adjustment then so....
