ATF in fuel to clean engine??? - Ford Powerstroke Diesel Forum
post #1 of 32 Old 10-17-2011, 04:45 PM Thread Starter
So a friend of mine suggested running a quart of ATF in a full tank of fuel to clean the engine out. He claims that his family does this once a year to their diesels both trucks and farm equipment. I am wondering if anyone has every done this and does it work? Thank you for any insight.
112motorsports is offline
post #2 of 32 Old 10-17-2011, 05:00 PM
GaryK's Avatar
When I bought my truck a couple of months ago. I asked a co-worker about fuel additives, he told me the same thing. I haven't used the ATF, I didn't know whether to believe him or not.
Gary
GaryK is offline
post #3 of 32 Old 10-17-2011, 05:22 PM
Quoted: 14 Post(s)
I'd be more apt to run Sea Foam through the engine because that's what it's designed for.
ttyR2 is offline
post #4 of 32 Old 10-17-2011, 05:31 PM
Galaxie's Avatar
Hum..... well, I dont exactly see how a qt would clean injectors. Now your truck can run on ATF, heck you can run a lot of ATF.
Also - anyone have any thoughts on sea foam? I havent heard much good stuff.
I am thinking if you need to clean your injectors, I would get a GOOD addidtive such as Opti Lube XPD. Maybe run a heavy dose of that.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #5 of 32 Old 10-17-2011, 05:32 PM
Quoted: 14 Post(s)
I haven't ever heard anything bad about Sea Foam. Can't say I've seen any lab results that says it actually cleans like it says it does.
ttyR2 is offline
post #6 of 32 Old 10-17-2011, 05:40 PM
back in the saddle
shu873's Avatar
I know dealer techs that burn used ATF and even some filtered engine oil as fuel in old 7.3's. Not that I'd recommend it unless you're fond of changing out injectors on a somewhat regular basis.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #7 of 32 Old 10-17-2011, 05:52 PM
Galaxie's Avatar
I just did about 10 minutes looking around. I am finding that people are stating that ATF will help clean. It looks like about half the people out there like Sea Foam, the other half dont.
I guess its like anything - see what works. I have found luck with the Opti Lube stuff.
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #8 of 32 Old 10-17-2011, 06:07 PM
I use it all the time. I try to put it in about every third or fourth fill up. Never had a problem only good results. Just pulled the injectors with 456k miles on them and they were almost spotless.
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #9 of 32 Old 10-17-2011, 06:10 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Every time I change my fuel filter, I fill the bowl with ATF and run it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 32 Old 10-17-2011, 06:15 PM Thread Starter
So how much do you add? I thought this might work as ATF is full of detergents, but was just a little skeptical. I will pour a quart in tomorrow as I just filled her up as well as change the fuel filter thanks for the help. Keep the coments comming.
