burning oil please help replaced injector o rings - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-16-2011, 12:52 PM Thread Starter
HankHill's Avatar
Hello, Im a active member on fte, I was active on here when I had my 6.0 stroke I now have a 2000 f250 4x4 6 speed manual with 7.3 stroke engine 155k miles I just did all 8 glow plugs and 8 injector seal kits, I used the OEM alliant o rings from riffraff diesel and did a oil change with rotella 15 40
truck smoke blue every morning for about 3 minutes until it starts to clear up smells of oil and it is oil doesnt matter if its plugged in or not, truck runs and drives like normal
if you bring it above 2k rpm at idle it will blow blue smoke and yes smells of oil
I am getting no oil in the tailpipe and my turbo shaft does not have much play, I think it is fine
rings on the pistons I highly doubt are shot at 155k
not sure about valve seals
I cant keep driving the truck like this, oh also it smokes under load, if I cant figure this out I'm going to just trade it for something I'm tired of working on it more than I drive it
so can someone please name off some things I can check into
thanks
2003 (build date 06/2003) f250, 6.0 stroke, automatic, 4x4, 3.73 GR, bought with 96k miles, ficm resolder, ccv mod, coolant filter, powersteering filter, straight pipe
HankHill is offline
post #2 of 10 Old 10-16-2011, 04:51 PM Thread Starter
HankHill's Avatar
ok, I have been searching all day
I have found a few cases where the injectors have failed internally and somehow was burning the oil
could this possibly be my problem??
someone please comment, I'm going to call my local diesel shop tomorrow to see how much they can get me remanned injectors
HankHill is offline
post #3 of 10 Old 10-16-2011, 11:27 PM
Govy Magnet
zambonimaxx's Avatar
Did you replace the injector cups when you did the o-rings? I could see a cracked injector cup causing this issue, especially with the RPM change and increase in smoke, as it would create more pressure.
~Phil
"Initial Success or Total Failure"
2002 F250 SC SB 4x4 7.3ltr
~leveling kit~35/12.5~B&W~MBRP 5"~4 Pod Gauge Pillar ~TW 6 POS~Mag-Hytec~LineX]~KC Long Range (Front)~KC Wide Beam (Rear)~Cobra CB~WW~CFM+~EBPV Delete ~6kHID's~OUO Blocks~3/4" Ubolts~OUO Adjust ladder bars~Full RR system w/ Fuel Bowl Delete~ CCV~BTS TRANNY
~ 6.0 Tranny Cooler ~ BHOF/Coolant Filter/ Fltr Mags
2012 Harley Davidson FXDB
2010 Jetta TDI traded for...
2012 Chrysler Town & Country
zambonimaxx is offline
post #4 of 10 Old 10-17-2011, 06:53 AM
ridiculously_necessary's Avatar
check injector cups. i suppose your valve sleas could be bad. but that isnt a common issue with the psd...
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #5 of 10 Old 10-17-2011, 07:16 AM
Ray Bennett's Avatar
Another vote for injector cups.
Just bought!, 1997 F350 CCLB 5 speed manual, For now the only mod is the 4" straight pipe
2002 extended cab long bed 7.3, 3.5" lift with 37x 12.50 Terra Grapplers on 17" Pro Comps, ts 6 pos chip, 05 grille, DIY 6637 air intake, 4" MBRP exhaust with muffler delete, Built trans with PI TC tugger shift kit and suncoast 5 disk drum, custom made one peice drive shaft, Edge CTS
Ray Bennett is offline
post #6 of 10 Old 10-17-2011, 08:25 AM Thread Starter
HankHill's Avatar
if the cups were shot I would have diesel in my coolant which I dont
or possibly not?
HankHill is offline
post #7 of 10 Old 10-17-2011, 08:40 AM
Govy Magnet
Possibly not, depending on the crack relative to the injector o-ring placement. It would more be fuel in oil as well I believe. But as mentioned before thats what I would think it is, especially if they are original and you have pulled the injectors before.
post #8 of 10 Old 10-17-2011, 08:41 AM
or possibly not?
Normaly you would, I just had a friend that changed his injectors and messed up his cups. As a result he had diesel in his coolant.
post #9 of 10 Old 10-17-2011, 09:02 AM Thread Starter
HankHill's Avatar
what is the best way to check the cups? shining a light down there?
HankHill is offline
post #10 of 10 Old 10-17-2011, 09:21 AM
Govy Magnet
I would just pull and replace. I think there is a tool that you need to pull and place the new ones back in, I have heard that you don't need the tool, but without it it is a serious PITA. Testing I don't believe would be worth it, I don't think they are that expensive, also a little bit better insurance for later on!
~Phil
