NEED DIAGNOSTIC HELP! - Ford Powerstroke Diesel Forum
post #1 of 10 Old 10-15-2011, 09:16 AM Thread Starter
The engine was running rough. I hooked up with a mechanic for computer diagnostic. codes that came back were, P1271#1 cyl high/low open, P0603 internal module KAM error, P1316 IDM codes.
Hoping this is just a sensor problem. Any ideas?
2000 F250 7.3L with 187,000 miles.
michael.payne is offline
post #2 of 10 Old 10-15-2011, 09:31 AM
ridiculously_necessary's Avatar
Check your UVCH. This is the Under Valve Cover Harnesses, they can come loose (there is a mod) and it can also burn the pins, so check for burned pins as well.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #3 of 10 Old 10-15-2011, 09:51 AM Thread Starter
thanks Matt, I will. I am new to diesel engines, the #1 cyl is on the passenger side closest to the firewall correct?
post #4 of 10 Old 10-15-2011, 10:03 AM
lol i dont know, i can never remember. i think its passenger side front cylinder.
either way the UVCH's are in the valley side, riight under the valve cover. i think on the SD its one connector each side... not 100% sure.
-Matt
DIY 6637
Marinco Mod
post #5 of 10 Old 10-15-2011, 10:18 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
Do you happen to have a chip in it? Usually the KAM code is thrown from the "flip chips"
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #6 of 10 Old 10-15-2011, 10:36 AM
Feedback Score: 5 reviews
I agree on checking the UCVH, may be time for the $.50 mod:
$.50 Mod Pics and Rocker Arm Torque Specs:
50 cent mod - Ford Truck Enthusiasts Forums
ToMang07 is offline
post #7 of 10 Old 10-15-2011, 10:37 AM
P0603 P0605 can both be caused by a chip or unplugging the batteries.
ToMang07 is offline
post #8 of 10 Old 10-15-2011, 10:45 AM
Winning DUHHH
Quoted: 8 Post(s)
Didnt know about the batts, Thanks for the tip!
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #9 of 10 Old 10-15-2011, 11:15 AM Thread Starter
thanks for all the tips. I am going to pull the valve cover this afternoon and check it out.
thanks to everybody and I will reply with what I find.
post #10 of 10 Old 10-15-2011, 02:32 PM Thread Starter
how much of a task is it to remove the valve cover on the passenger side? I'm a shade tree mechanic and I was looking at it and it seems to me that's a pretty big job. lots of stuff in the way. any advice? I would like to attempt this myself and save a couple of dollars but I don't want to make it worse either.
2000F250 7.3L
