Fluid types and weights - Ford Powerstroke Diesel Forum
Old 10-13-2011, 02:25 PM
I have a simple, but important questions.
My truck did not come with an owner's manual.
What weights and fluid types should I use in the various parts of my truck.
Early 99 F250 4x4 auto 7.3
Engine Oil:
Tranny Fluid:
Transfer Case Fluid:
Rear End Fluid:
Front End Fluid:
Power Steering Fluid:
Brake Fluid:
Washer Fluid: (lol, no, not really)
Thanks In advance,
Brian
Old 10-13-2011, 02:52 PM
Go to Official Ford, Lincoln & Mercury Owner Site | Personalized Owner Information
Click on Vehicle basics
Click on owners manuals and videos
That will take you to a page where you can get manuals online.
99's may not be there, but 2000 or 20001 should be the same.
Old 10-13-2011, 03:04 PM
Awesome, just what I'm looking for. Previous owner snatched the manual when doing the final "cleaning out" before I took the truck.
Old 10-13-2011, 04:17 PM
Engine Oil: Any CJ-5 diesel rated oil. I've run Motorcraft 15w40 and Rotella 5w40 synthetic with great results
Tranny Fluid: Mercon ATF
Transfer Case Fluid:Mercon ATF
Rear End Fluid: Synthetic 75w140
Front End Fluid: Synthetic 75w90
Power Steering Fluid:Mercon ATF
Brake Fluid: Dot 3
Old 10-14-2011, 09:08 AM
Send a message via AIM to rufushusky
Engine Oil: Any CJ-4 motor oil
Tranny Fluid: Mercon or according to FoMoCo Mercon V (it is been debated what will happen to your trans since when the 4R100 first came out Ford didn't spec Mercon V but now it says its ok to run it) Do a search for Mercon V, lots and lots of threads on it.
Transfer Case Fluid: Dex/Merc ATF
Rear End Fluid: Synthetic 75w-140 for SRW, 75w-90 for DRW
Front End Fluid: 75w-90, doesn't spec synthetic but it is not a bad idea
Power Steering Fluid: Mercon ATF
Brake Fluid: DOT 3
Thanks In advance,
Brian
Answers in red....
Old 10-14-2011, 10:09 AM
coolant
Do you guys use an additive to the coolant? My manual says I should but I have not.
Old 10-14-2011, 10:47 AM
If you have green coolant you should check it every 15k miles or so if gold I would check it once a year.
Instructions are in this for gold:
http://www.fectrucks.com/fec/dmdocum...ord64maint.pdf
Or you could flush in an ELC and only need an additive every 3-4 years.
Old 10-18-2011, 06:26 AM
Thanks for the link. Is this good for the 7.3L?
Old 10-18-2011, 06:44 AM
Depends on the coolant you have in your 7.3.
If you have green you should follow this:
https://www.powerstrokediesel.com/in...=305#intervals
Under 6.9 and 7.3.
If you have Gold, you follow the same intervals as the 6.0s as in the link above. Basically you are checking the nitrate strength every 6 months and adding more as needed.
If you have ELC, you ignore both and just add an extender in 3-4 years depending on brand and run the coolant for 6-8 years total.
Old 01-16-2012, 07:25 AM
Boot, scoot and boogie
How much ATF does the transfer case hold?
