2000 psd starting Issue - Ford Powerstroke Diesel Forum
Old 10-13-2011, 10:05 AM
I have a 2000 psd f250 4wd 7.3. Im having a issue with starting it at times. Most times it fires right up. But some times all I get is a click from the engine compartment. and it won start till i take it from park to neutral. than it fires right up. At first i thought it was a starter issue dead spot or something. But Ive got under there and smacked starter with hammer and that hasnt done a thing..... Any ideas sensor or something? shifter going bad? Trannie problem?
Old 10-13-2011, 02:30 PM
I would assume maybe some sort of sensor that tells your computer something or another about the gear it's in.
Old 10-13-2011, 04:22 PM
Sounds like your transmission sensor is out of whack. Try lifting up on the shifter. There's some brass torx bolts underneath the column/dash that like to come loose and cause this issue.
Old 10-14-2011, 03:13 PM
S if I pull the column cover off Ill find the torx bolts?
Old 10-14-2011, 04:18 PM
No, stick your head up under the dash.
