injector install help needed
I have installed many injectors but feel I have had problems with the remans ticking. I bought a new alliant injector today and installed in in place of an old but quiet running injector. The thing is I always coat the o rings with oil. I remove the glow plug and crank the motor to not hydro lock it. One thing i never do is this(taken on line from black cloud diesel)
" After checking the oil level, but with the injector wires disconnected so the injectors will not fire (You can also remove the #9 Maxi fuse in the under hood Power Distribution Box), crank the engine for 30-40 seconds to get oil circulating and pressurizing. Then continue with reassembly and crank the engine for 30-40 seconds every 15-20 minutes, or until you complete 4-5 cycles. This cycle of cranking andresting gives time for air in the injectors to bleed out and work its way to the top of the rails. When everything is reassembled and you're ready to start the engine, top off the oil rail and reservoir one last time. If the engine is started while there is still air inside the nozzle, there may not be sufficient fuel to cushion the nozzle needle and it can crack the nozzle tips. Air inside the fuel cavity of the plunger and barrel has similar effects on the piston." When i first tried to start my motor(i only removed one injector so did not lose much oil in the rails or fuel, went fast) The engine started with in say 5 seconds. i did not have to crank long. The motor or actually this new injector fired blanks for a few seconds. i could hear it going snap snap snap. I turned the motor off and restarted it. That was gone but i now have my annoying as all hell tick tick tick back. The old injector was fairly quiet. I had tried 3 injectors from beans remans, and now one new one. several different holes but they were ticking. Its like I get 1 out of 4 to go in and be quiet? any ideas? |
bump anyone???
