What gauges should i get. - Ford Powerstroke Diesel Forum
Old 10-10-2011, 05:21 AM
I've searched this but still not sure.
I am looking at the 4 gauge pod from GlowShift after 10% discount its $230 shipped for the pod and gauges.
I think I want 60psi boost gauge
1500deg EGT gauge
Trans temp gauge
Not sure what to get as the 4th gauge. Fuel pressure? Oil pressure? Oil temp? Water temp?
I dont think i will ever go past upgrading exhaust intake and a programmer. Maybe injectors at some point but i think thats about it.
Old 10-10-2011, 05:44 AM
I'd get fuel pressure, can help resolve issues in the future, especially if you start on altering the fuel system.
Just my $0.02
Old 10-10-2011, 06:57 AM
That makes sense. What about oil pressure. Is that very important to monitor?
Old 10-10-2011, 07:02 AM
Certainly, however the LPOP (low pressure/lubrication pump) supplies the HPOP that supplies the injectors, so from what most say, if the LPOP fails, the engine will quit before doing serious damage due to lack of oil supply/lubrication. However, if it still weighs on your mind, don't hesitate to choose it. I'll install one some day, it's just not as "crucial" as the other gauges/parameters, as most will agree. Not much for oil pressure issues that way with these trucks luckily.
Again, my two cents.
Old 10-10-2011, 07:05 AM
Thank you. All this lpop hpop talk is still very new to me. So I'm trying to learn as fast as I can.
Old 10-11-2011, 11:31 AM
Powerstroke Junkie
Buy some decent gauges and leave the Glowcrap gauges to the Ricer's. Isspro or Auto Meter, with Isspro being my number one choice.
Good Gauges are not Cheap, and Cheap Gauges are not Good.
Old 10-11-2011, 11:45 AM
What u talkin bout willis
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
i would disagree....
i ran a set of isspro perfromax's and had nothing but problems.... gauges bouncing all over the place, sometimes just quit reading....threw them away....
i had a set of glowshift elites and not one single problem with them after two yrs of running them.... there still prolly working flawlessly...
now has glowshift had a problem before? yea they have... but from what ive seen there alot better now...
The Silent Service
With a 7.3L, I think you'd be fine with a 40psi Boost gauge unless you are building this truck for major power.
I agree with the 1500* EGT and Trans Temp gauges, and would put Fuel Pressure in the last slot.
However, I would not skimp on the quality of the gauges you install. Buy better quality units, and not worry about replacing them. I run AutoMeters for that reason.
Old 10-11-2011, 12:15 PM
Thanks guys for the input. I would go with a 40 psi but the gauges are either 35 or 60 psi for boost gauge. So ill go with 60 psi.
Old 10-11-2011, 12:41 PM
My buddy had a 60, but sold it to buy a 35, because you'll only (want to) hit 30 with the stock turbo. Plus it's a more precise reading on a 35psi gauge.
I bought Autometer for known quality. If you really wanted the best monitoring setup, get pyro, boost, trans temp and then a scangauge in the 4th.
