Excursion lift on a super duty? - Ford Powerstroke Diesel Forum
Old 10-08-2011, 02:45 PM
Have a chance to get a used lift with everything I need off of the same year excursion as my truck. 4x4. Leaf springs. Blocks in the back. Will this work on a truck also?
Sent from my DROID X2 using AutoGuide App
Old 10-08-2011, 03:16 PM
Might not get the samelift as the excursion. My 6" lift is a 4"lift on a pickup. Not sure why.
Old 10-08-2011, 03:19 PM
Ok. As long as it fits thats all I need
Old 10-08-2011, 06:49 PM
If I remember correctly, my buddy had an excursion and told me this, the excursion sits 2" lower than the truck from the factory, therefore a 6" lift on an excursion is the equivalent of a 4" lift on a pickup since it started 2" taller than the ex. Not that the same kit 6" on an ex would only net 4" on the truck. I may be wrong.
Old 10-08-2011, 07:24 PM
The guy with the excursion said he has a five inch lift on it? Didn't think they made that. Anyway if the lift is lower on the truck I won't need a carrier bearing drop right?
Old 10-09-2011, 02:01 AM
it would be in your best interest to get a carrier bearing spacer.....IIRC for every 1" of lift the carrier bearing needs a 1/4" shim....
Old 10-10-2011, 11:49 AM
U need to check with a shop. It should still lift your truck five inches. From my understanding if u put the same 4" kit for example on the two vehicles, the x would be 2" lower therefore it requires a 6" lift to sit as high as a pickup with a 4". I don't think it means that a 6" lift on an x will net only 4" on a truck.
Sent from my fone.
