fuel pump test - Ford Powerstroke Diesel Forum
Old 10-08-2011, 12:05 PM
fuel pump test
Is there a test location under the hood? What should i have for pressure?
I have no issues, just preventative maint. I'm @ ~130k on the original part assuming it could use to be replaced before snow flies.
There is a frame mounted electric pump? - is that the only one?
Know of any quality replacement pumps? -Is using the Motorcraft part worth it?
Thanks for any info!
-d
PS: truck detail in sig.
Old 10-08-2011, 01:50 PM
Probably have to test pressure at the fuel bowl. I know that's where everyone does.
130k on a stock pump? Try 315k, and i'm not even worried about it. If anything you're FPR would go out first.
Yes, that's the only pump. It sucks out of the tank then pressurizes to the bowl.
60-75 or so is good.
Old 10-08-2011, 06:01 PM
thx!
I'll see if I can check it tomorrow. Also, good to know they last a while.
