CCV mod? - Ford Powerstroke Diesel Forum
Old 10-06-2011, 01:26 PM
CCV mod?
I have the CCV mod done but i have seen that everyone turns there doghouse around and runs the hose. I turned my elbow coming off the dog house down and ran another hose straight off it and down my frame. Is there any reason not to do it this way? I just didnt understand the extra steps of taking it off and replacing o rings unless there is another reason.
Old 10-06-2011, 01:35 PM
Chapter Director
Did u plug the hole into ur intake im bout to do this alao
Old 10-06-2011, 02:12 PM
I cut a 4 inch pipe i had extra of and replaced that section of the intake so i didnt need to plug the hole.
Old 10-06-2011, 02:14 PM
CSP Resident Spooby
I don't see any reason why it wouldn't work the way you have it, I had mine venting along the frame by the transfer case for a good 10 months with no issues.
Sent from my DROID X2 using AutoGuide App
Old 10-07-2011, 12:16 AM
So there really isnt a reason to take the part off the top and turn it around to face the firewall? Everything clears and it makes it easier to put back to stock for inspections.
Old 10-07-2011, 12:52 AM
You need to have a high spot before it goes down to your frame or else you will loose ALLOT of oil.
Old 10-07-2011, 01:13 AM
Run it up over the brake reservoir then down the frame...that will keep the oil from running down the hose
Old 10-07-2011, 06:12 AM
X2. I routed mine up over the brake booster and havent dripped any oil at all. just the normal ccv exhausting smoke.
Old 10-07-2011, 10:15 AM
CSP Resident Spooby
I had mine running straight down off the doghouse and never notived anything but a drop every now and then. I just figured it was residue from the smoke
Old 10-07-2011, 11:23 AM
so here is my question. i and fairly certian i have a good deal of oil in my CAC. what sthe best way to get it out? pull the whole cooler? it would be awesome to drill a hole in the bottom and seal it back up with a plug imho...
