No cruise control or Tow/haul - Ford Powerstroke Diesel Forum
Old 10-04-2011, 05:46 PM
I have had my (new to me) 2001 F250 Lariat 7.3 or a little while now and i have no cruise or tow/haul and it is starting to bug me, no switchs work or any lights on the dash. i recently had the cam position sensor and speed control module recalls done and it did not fix the problem? any help would be appreciated!
Old 10-04-2011, 05:49 PM
There is no tow haul. Guess you mean the OD light.
Did you check all your fuses?
Old 10-04-2011, 05:50 PM
Yes sorry i ment the overdrive on the end of the shifter, and yes all fuses are fine
Old 10-04-2011, 05:58 PM
Ok fuses in the batt junc box too?
Sry just covering basics.
Other than that I'd say a loose connection or frayed wire?
Old 10-04-2011, 06:05 PM
yes i have checked those too, would the frayed wire be in the steering console? would you happen to know where i can get a wiring diagram for my truck?
Old 10-04-2011, 06:08 PM
You might can search on here for one. Try the 7.3 tech files.
Old 10-04-2011, 07:06 PM
You will most likely need to get a now gear selector from Ford. The wire gets pinched inside and eventually break. Very simple to replace.
Old 10-04-2011, 07:09 PM
would that cause my cruise control issue as well?? can i splice in a new wire or is that not an option?
Old 10-04-2011, 07:38 PM
Ok is it just the cruise and OD light?
Or all the lights on the gauges like you said? Radio included? Power lock/window lights?
Old 10-04-2011, 07:42 PM
yea its just the OD and cruise not working, i ment that there is no lights lite in the dash, everything else works
