help!
so i disconnected these wires over a week ago, should have taken a pic but didnt. didnt think the truck woul dbe down this long so i went by memory.
where do these wires go? which post(s)? i know one is the AIH and i dont really need it, but where does the other one go, the loop connector? right post? gotta get this running tonight... ![]() and where does this guy go?
Matt your pic isnt working for me.
ok, found the AIH wire... DUH!
the other looks to be a ground. does it go to the connector on the right? where does the little white plastic and metal spacer go? |
are you wiring the AIH relay or the GP relay or what?
im putting the spider back on. doign the wvo conversion and had an unextected week or so delay. wife needs a vehicle tomorrow.
IIRC the little shotgun shell brass looking thing is a spacer on the AIH. I think it goes on then the two wires go on and it gets held on by a nut. then the little solenoid pump thing gets bolted on the spyder. if that doesnt work let me know and I'll run to my parts and see what my spyder looks like. should start and run just fine w/o it though.
that sounds right. ill give it a try.
again lemme know if it doesn't work
The wire with the big eye goes on, then the spacer, then the wire with the nut. That is just an intake air heater... I plugged mine with a 22 x 1.5 plug. You can find these threaded for a fitting to put ur boost pressure gauge on.
