Transmission Fluid Change and Adjust? - Ford Powerstroke Diesel Forum
Old 10-02-2011, 08:04 PM
Going to flush the tranny and am wondering if there are any band adjustments to do inside the transmission while I have the pan off.
Old 10-02-2011, 08:07 PM
There's no need to drop the pan, there's a drain plug.
Old 10-02-2011, 08:17 PM
Feedback Score: 5 reviews
True, but it's the only way to replace the filter and check for wear metals.
Old 10-02-2011, 08:18 PM
Drop the pan. And do about a 21qt flush. Just draining and filling is NOT a flush. No where near.
Old 10-03-2011, 04:18 AM
Yep, got about 20 quarts to replace with. Changing filters. I just wondered if there are any adjustments to madge while the pan is off.
Old 10-03-2011, 02:50 PM
Nope. Nothing to adjust. You could always put a new valve body in while you're there.
Old 10-03-2011, 03:51 PM
Cool, Thank You very much.
