Ooooo Shiny - Ford Powerstroke Diesel Forum
post #1 of 1 Old 10-02-2011, 02:09 PM Thread Starter
late_99_PSD's Avatar
Quoted: 10 Post(s)
Talking Ooooo Shiny
Well I got tired of the stock, bleek, gray aluminum wheels So I decided to do...ALOT of work to get them looking a bit better, just in time for winter
First you have to get the wheel off
Next you have to get the wheel weights off, make sure you mark where they go before you remove them.
I used a chemical stripper normally used to remove poly and stain from wood.
Now you gots to rub it all in
After a bit the clear will start to peal and bubble off.
Next you have to get a plastic scrapper of some sort and get off whatever clear that the stripper left behind. Once you get it down to bare aluminum you have to start polishing, and polishing, and polishing, and polishing, and polishing
Then after a bit of clean up they start to look pritty good
I finished up with a polish/protectant I got from Advanced Auto.
Hopefully this will inspire you to get off your computer and make your truck a bit better looking
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
