Overhead display questions - Ford Powerstroke Diesel Forum
Old 09-29-2011, 10:55 AM
Winning DUHHH
Hey guys, can the overhead display be installed fairly easy in a truck that didn't come with one originally? The temp, and miles remaining etc...
Any insight would be appreciated!
Thanks guys
Tony
Old 09-30-2011, 04:37 AM
Powerstroke Junkie
YES
There are several write up s on it. Google is your friend.
You will need the console unit, the harness that goes from the console to pass side foot well. Some have said the temp sensor is already there even if you don't have this option, but you will need to verify this on your truck. If I didn't have the overhead I would be adding it too.
Old 09-30-2011, 04:50 AM
Do you know if the fuel remaining calculation works off a know tank volume or is it a calculation of miles traveled from full to empty? Reason I'm asking is I would like to replace the tank on my Ex with a larger one and it would be nice if the miles left calculation worked. I've tried searching for this with no success.
Old 09-30-2011, 06:12 AM
Winning DUHHH
Originally Posted by NCHornet View Post
YES
Yes, I used google, and could only come up with the same questions as I was thinking in my head. I did see mentioned that the passenger kick panel needed be removed to check the plug. I did that, and noticed both plugs I have are already plugged into something. I can post a pic of said plugs if youd like. Also, are both plugs used in the factory harness when bought? my plug nearest the door has i think 2-3 wires in it, and the other plug closest to the firewall has about 8.
Let me know,
Thanks, Tony
Old 10-01-2011, 03:31 PM
This would be a great mod.
Scott
Old 10-02-2011, 06:42 AM
Powerstroke Junkie
I know there is a right up over there too, but I don't have time to find it for you. It's there, many have done it.
Overhead console install? - Diesel Forum - TheDieselStop.com
Adding Overhead Console to 02 F350 - Diesel Forum - TheDieselStop.com
FORD F-series Overhead console kits and Parts
