Quick question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-22-2007, 06:25 PM Thread Starter
Cj Ford's Avatar
Quick question
Ok I was out being a tool in my truck today and well I slipped the Southbend con ofe pretty good, it made a bit of smoke and you could smell clutch.... think it will effect the way that clutch was performing?do you think 1 time is enough to glaze it and have it be junk...(i dont but someone who thinks they know everything about everything said oh it is junk now it will never grab like it use to) this is the first and only time I slipped it since it has been in less then 2 months... it feels normal still
sorry if you think this is a dumb question but im jus curious as to if i just baffed it being a retard
1999 F250 XLT 2WD 7.3, 6 spd, South Bend Con OFE, Detroit Truetrac, Tony Wildman tunes, Autometer Boost&Pyro, AFE Stage II, 4" MBRP Exhaust, 2" Daystars, 17x9 DC1 wheels wrapped in 33x12.50 MTZ's
Chris
Cj Ford is offline
post #2 of 9 Old 08-22-2007, 10:33 PM Thread Starter
Cj Ford's Avatar
btt for the dayshift
Chris
Cj Ford is offline
post #3 of 9 Old 08-22-2007, 10:56 PM
PIPE HITTER
gcop's Avatar
I would not think one time would hurt anything. I used to have a car that I ran at the track, and there were a few times I would slip the clutch trying to get outta the hole, and when I did, I just took it easy down the track, let the car sit and cool down, and then all was well.
I would not at all expect that you would see a problem. If you slipped it a whole bunch, with out giving it a brake at all, then I would say damage would be possible. But a one time thing, I'd say you good
"Life is hard, it's even harder when you are stupid"
gcop is offline
post #4 of 9 Old 08-23-2007, 05:18 PM
lilredpowerstroke's Avatar
On my 99 the first time I pulled a sled with it, I slipped my clutch really really really bad. I let it cool down and pulled with it again maybe 15 minutes later and it held pretty good in fact its still holding
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #5 of 9 Old 08-23-2007, 05:20 PM
The Fat Mod
Logan's Avatar
I would not worry about it too much
Logan is offline
post #6 of 9 Old 08-23-2007, 05:35 PM
WEWILLE's Avatar
Dont worry, i taught my sister how to drive a manual mustang, it was tough and very hard on the clutch, but it still grabs good.
ASE Certified Master Automotive/light duty truck Technician
ASE light diesel specialist
Ford Certified Diesel Technician
Isuzu Certified Gas/Diesel Technician
2007 F-250 PSD FX4 crew cab shortbox king ranch
2005 F-250 PSD FX4 crew cab short Box burned up
2013 Fusion 1.6L Ecoboost
2011 Ford Edge
1999 Dodge 2500 Cummins
WEWILLE is offline
post #7 of 9 Old 08-23-2007, 07:01 PM Thread Starter
Cj Ford's Avatar
Wink
well i was kinda sled pulling i guess you could say too
I hooked to a friends chebby 1500 4x4 Z71 pick up and drug him around on dry pavement using 2nd gear, not including the creeper gear..I normally wouldn't do something like this but it was a total call out on his part. it was a well my 4x4 could out drag that diesel if I'm in low range 4wheel drive.... so after I told him he was a FAWKTARD I decided to do it, everyone had a good laugh as he was spinning in forward as I drug him backwards (1 front wheel and one rear guess he has open diffs)..I kinda cheated as I had about 600lbs of steel plate in the bed too... so I got calky and then tried to do it in third ... well it did it but that's what caused the smoke and smell...I wont try that again Ill stick to 2nd
Chris
Cj Ford is offline
post #8 of 9 Old 08-23-2007, 07:38 PM
Rice Hunter
Diesel Freak's Avatar
HEY,,,,,YA THINK YOUR BUDDY WOULD LIKE TO COME ALONG TO THE MEET & GREET?? THIS WOULD BE FUN!!!
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #9 of 9 Old 08-23-2007, 07:43 PM Thread Starter
Cj Ford's Avatar
I swear he is retarded!! It started cause I was telling a few guys at work how my truck pulled like a freight train with the 6 speed its un real.. well I guess he wanted to see for himself...
I bet we would need a few sets of tires for him and lots of this goin on :burnout
Chris
Cj Ford is offline
