Boost psi - Ford Powerstroke Diesel Forum
Old 08-21-2007, 08:11 PM
Boost psi
after installing my gauges I took it for a run 0 psi at idle and at 20 psi @2400rpm it was blowing the plastic hose off 4 times in a row!!!!... well everything is closed tonight sooooo I crazy glued the hose into the rubber fitting (temporary fix) I need to make a T using a compression fitting like on the back of the gauge...
anyway my Q is I can only get about 23 psi max no load or anything.. it hits the 23 fast then the needle shakes and shimmys a bit but goes no higher.. is this normal 23psi @ full throttle??? its a early 99 with the superchips if that matters
does anyone know what size the hose off the map is so i can get the fittings and the plastic hose size too so i can get a compression fitting
Old 08-21-2007, 10:48 PM
BTT for the day shift guys! I'm kinda concerned on the low boost psi..I hope my turbo aint taking a crap on me
Old 08-21-2007, 10:51 PM
i only get like 28 psi sometimes 30 psi that maxing it out though you should be good.
Old 08-21-2007, 11:00 PM
I get bout 29 to 30 with the bully dog flip chip
Old 08-22-2007, 12:33 AM
I can get to about 25ish, before I feel the computer de-fuel.
Time to get a MAP fooler.
Old 08-22-2007, 03:17 AM
thats around where it should be with a superchips. get a map fooler and ull prolly get a lil bit more out of it. that line is 1/4" if memory serves me correct.
Old 08-22-2007, 06:02 AM
where do i find one?
if I was runing a different tuner would the boost be higher? Like if I had a custom tune by tadd jody todd ??
Old 08-22-2007, 03:02 PM
yeah prolly would.. an edge would give it a noticable difference in power and smoke(if thats ur thing, i know its mine ) and a custom one prolly would too. and u can find MAP Foolers just about anywhere at a diesel performance site. they r about 80 bux or so. they have them at blackclouddiesel.com i know for sure, thats where i got mine.
Old 08-22-2007, 03:11 PM
Anything over 25 can be self defeating. The stock turbo is only designed to run 25 max anything over that and you are out of it's map not to mention just making HOT air.
More boost does not always mean more power.
JMHO...
Old 08-22-2007, 03:14 PM
International Threat
Early 99 = smaller turbo = lower boost #'s = 23 ain't bad.
I hit 28 at WOT for a few seconds, more commonly run 25-26psi.
