Pulled a couple codes
Truck didn't seem to be running quite right, when I go WOT it doesn't smoke as much as it used to. I checked for codes and I got two.
The first was: P0748: Exhaust pressure control valve. high output The second was: p1211: injector control pressure above/below desired. I have been running an edge evolution on xtreme, would that make a difference? I didn't pull these codes last time I checked for them, and I recently changed the injector control pressure sensor, or whatever it's called! |
I believe the 1211 is the hpop not putting out enough pressure for the extreme setting.
What would be the possible solution OTHER than spending a truckload of $$$$ for a high performance hpop?
Really the only fix I think is to buy a custom chip or tuner or dual hpops to supply more oil. You still might get that code with a custom chip or tuner also, so I wouldnt worry about it too much.
So the edge evolution is poop?
I've REALLY been looking for a custom tune/tunes. Any suggestions? What is an SCT? |
No I don't think the edge is bad, but custom tunes is where its at now. Here is a link to SCT's website. Its a tuner that can upload custom tunes from a programer like DJ by email and then download them to your truck.
Ooops forgot the link SCT Flash Devices - MORE Power . . . Period!
MAN, I NEED TO GET OUT OF THE CONCRETE BUSINESS! |
I love my SCT...have basicly a stock 6.0...ran the 1/4 mi in 14.3 at 93+mph...all I did was a tuned SCT and separated the exhaust before the cat just for that day to attempt to keep the EGTs down since I was running at the track all day.
Anyone know about the exaust code?
