ABS Front Sensor Testing - Ford Powerstroke Diesel Forum
Old 09-09-2011, 12:41 PM
Is there anyway to check, by a possible Ohms reading which ABS sensor is bad on the front of a 01 4x4 to see which sensor needs replaced so the light goes off???
Old 09-09-2011, 02:20 PM
I don't know what you might get by ohming the sensor, but a good scan tool will tell you which sensor has the problem.
Old 09-10-2011, 05:00 AM
yeah. I was going to figure out if their was an easier way. I have an ohms meter, just not easy access to a good scanner.
Old 09-10-2011, 06:13 AM
I just tested 2 I had hanging on the work bench from a 2001, one tested 717 ohms the other 720, both were good when they came off the truck with the old wheel bearings. Hope this helps you out.
Old 09-13-2011, 06:26 AM
Thanks for checking. I am probably going to try and check mine real soon. I figured the Ohm's may show some indication.
