Overdrive Issue????
I'm new to this forum as of today, looks like a lot of info on the powerstrokes
This may have been an issue with some of you so hoping I can figure this out with some help from all of you Problem is sometimes when I first start my truck (2000 F-350,7.3 L Auto.) my overdrive light on shifter button is blinking , When I put the truck in drive and take off , my speedometor, odometer, cruise don't work . I can stop the truck ,turn off ignition and start all over and it will work correctly ,everything works. Has anyone had this to happen and what is causing this . The other day I started the truck took off and I noticed the overdrive light was staying on , Couldn't change it by the button on shifter and the overdrive didn't kick in. Stopped, turned off ignition started over put shifter in drive went on my way no issues , What in the H### is going on ... any help would be usefull
Go to the problems page .Page 2. Fourth from the bottom. clancy1920
I have the same problem but doesn't happen to often. Haven't fixed it yet. clancy |
Overdrive Light Blinks Or Stays On
I Had The Same Problem On A 1999 F250, There Is A Speed Regulator Switch On Top Of The Rear Differential, $11.99 At The Parts Store, Held On By One Bolt, Disconect, Plug In New One And Bolt Back On. Took 15 Mins And Saved Me $148.00
