- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Bypass coolant filters
Anyone have experience in running one on a PSD? Probably not needed but I know some of the big rigs run them, don't they? Thought about installing one prior, during or after coolant change; haven't picked yet.
Dieselsite sells a kit for around $80 bucks, you could easily make it yourself cheaper I suppose. |
| Sponsored Links |
I got the kit last week along with a few extra filters, and I got around to installing it on Saturday. I ground down a 3/8 extension somewhere in the neighborhood of 5/16 to get access to remove the bypass plug on the water pump, I know there is a special tool (Probably expensive) for this but I think sacrificing a small extension worked good enough or what also would work if you had some 5/16'' keystock. It's probably a metric size on the plug though if I remember reading correctly. I'm going to screw in a temp gauge on one of the blocked off ports, and maybe shorten the hose from the pump to the filter housing. It's working, I guess I'll have to cut open a filter in a month or two. ![]() ![]()
It was one of the first mods I did to my truck, it will save your water pump. Our trucks are constantly leaching sand from the casting of the block. THIS SAND WILL DESTROY YOUR WATER PUMP!!! Run it until after the truck is run for awhile you can grab the filter and it is still cool, this means it needs to be changed, cut it open and you won't believe what comes out. I get the filters from Napa for under $5 each. I mounted mine down on the frame, there is a nice pocket behind the front tire that it fits perfect in. I used two HD gas ball valves, I can change my filter and not loose a drop of coolant. Bob use to charge $65 for the kit, at $80 I would just by the parts and do it yourself, all it is is an aux, oil filter mount and some hose, and a few barbed fittings.
I see one hose comes outta the overflow bottle right? but whre does the other one go to???
| Sponsored Links |
