7.3 almost dead, runs rough, no power
Had to get it towed home last night. Me and my gf went a few miles down the road to get a movie, running fine , pulled in the parking lot and it had a very small lope to it. Shut it off, went it for 5 mins come back, checked oil just in case, started it and lope got worse immediately and when I starting out of the lot truck started shaking and loping hard like it was running on 6 cylinders. I stopped and checked to make sure my chip was in good and no change. Decided to try and limp home. Truck would barely go 15 mph and would no pull up a very small hill, pulled over, and had it towed home. I think Im gonna try to borrow the scan tool from advance and see if it will tell me anything since advance auto is the only place open today
![]() So what do yall think? Is this a CPS problem? Im thinking its an injector(s) issue, like one went out and I lost oil pressure to the others? I dont think its bad fuel because I have 300 miles on this same tank and its been running like a champ. And oil was change 1000 miles ago(rotella), fuel filter around 6000 miles ago. Thanks in advance |
Just throwing this out there. Could it be the FICM? Our truck clanged banged jerked and reatteled and finnaly quit till we replaced that.
Mines a 7.3, not a 6.0.
Sounds like a UVCH to me. If you have the time pull the valve covers and check it out, I'm willing to bet one side is loose.
Thanks Mang. Im hoping it something like this and not more serious. How long does it take to get the valve covers off? And I was thinking I might do a buzz test if the scanner at advance can do it
Know anyone local with a good scanner like AE or otherwise? I haven't removed mine yet, but It doesn't look that hard. Maybe 1-2 hours tops. just take your time and don;t loose anything, lol!
Well, if U got the time, go diggin! lol! One more thing to check for when u get to the UVCH, check the center pin in the harness for any signs of being burnt. If it is burnt, you will probably need to replace the harness itself. |
This sucks
