Air filter question? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-30-2011, 04:00 PM Thread Starter
Ford Cowboy's Avatar
Quoted: 5 Post(s)
Just installed a fram tough guard TGA9400 stock replacement air filter in my truck and was wondering if i needed to oil it? It says on the box that it comes pre-oiled, but I was wondering if that was enough. Thanks
Ford Cowboy is offline
post #2 of 6 Old 08-30-2011, 04:05 PM
uhm oiled? I wouldnt run an oiled filter on a powerstroke.. muchless a fram.. Do a DIY intake and enjoy knowing and hearing that your truck breathes better!!
Dietoremain is offline
post #3 of 6 Old 08-30-2011, 04:17 PM
JEL
^x2 agreed
But for the time being, I wouldn't add oil. It probably just has some kind of light haze on it to keep it somewhat resistant to moisture or storage, so it should be good to go.
JEL is offline
post #4 of 6 Old 08-30-2011, 04:18 PM
Feedback Score: 5 reviews
Yup, Fram is GARBAGE. (Oil OR Air)
DIY is easy enough to do, and will save you a TON of money in the long run!
ToMang07 is offline
post #5 of 6 Old 08-30-2011, 04:27 PM Thread Starter
Quoted: 5 Post(s)
Guess i'll be doing a diy intake at some point
post #6 of 6 Old 08-31-2011, 07:15 AM
highrpm's Avatar
Just to elaborate on this,..I just did the 6637 DIY on my sons 2000 7.3 last night, and it had been refiltered with Fram's for a long time from the prievious owner...we took that thing apart, and looked down the intake tube to the turbo wheel, and I was shocked at how much dirt was in there...all the way to the turbo intake aluminum housing!!..needless to say, we unbolted everything and gave it a good scrub down inside and out. The turbo hand spun just fine, no binding or odd movement, just a little debris on the fins which I wiped down. Got everything back together with the 6637 and I am going to inspect the intake after about 1000 miles or so to keep tabs on how good its working....but to sum it up...Fram is junk.
2000 Powerstroke 7.3 F250 Lariat 'bout to roll 155K...Oh wait!..it already did!
6637 DIY intake,PHP Pheonix 6 and Straight Piped.
"If it has tits or tires..you're gonna have problems"
highrpm is offline
