Oil in Valley?
I changed the 3 oil rings on the fuel drain because there was diesel fuel in the engine valley.
After a week, I noticed fluid in the engine valley and I thought I messed up the new o-ring procedure. However, this evening I finally took a good look and after cleaning it up with paper towels, I discovered it was oil in the engine valley. I did an advanced search to try and find answers to the cause of this problem. What is the most common culprit for this? I don't want to dive into this without getting some opinions on this.I am looking at the HPOP replacement o-rings, but also wonder if the plug should be replaced too... Thanks! |
if the oil is toward the front then yeah prob. hpop o-rings leaking or even the oil tank / timing cover upper gasket leaking..
if from rear could be turbo pedastal oring leaking.. is leak more in front or rear? pics would help also.. |
Thanks...
After looking a little closer it looks like the oil is coming from the bottom of the turbo...so I am going to look at the turbo pedastal. |
might want to look into a gutted pedastal and ebpv while since you have to remove the turbo anyways.
