Question about pressure washing engine - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-27-2011, 08:42 AM Thread Starter
Quoted: 14 Post(s)
The 7.3 in my 2000 f-350 is filthy, and the usual places (intake boots, air cleaner boot) are covered in oil and grime. Does the valley between the cylinder heads drain off the back of the engine, or will I need to blow the water out of there when I'm done pressure washing the engine? I'll be keeping the water away from the electrical parts as best I can.
ttyR2 is offline
post #2 of 2 Old 08-27-2011, 10:46 AM
You should be ok the connectors are water resistant
And a good tip at the DIY car wash rinse with the wax
It will leave your Eng looking good a prevents dirt from baking
On and easier the next time you wash
And if you have nice wheels use the wax on them too as
It will be easy to clean off the next wash too
2000 F550 DRW. 4x4 manual Trans
AIH delete
Glow shift guages
98gal transfer flowtank
Riffraff 6637 kit
Ccv mode
Wicked wheel
4" mbrp
PAC brake with aux air tank to air stuff up
TS chip 6 pos
Riffraff hpx crossover
Vdryv is offline
