2000 F350 4door , 2 wheel drive to 4 wheel drive conversion - Ford Powerstroke Diesel Forum
post #1 of 2 Old 08-26-2011, 09:33 PM Thread Starter
I have a 2003 drone 4 wheel drive F350 that I would like to use the components of to convert my 2000 to 4 wheel drive.
Does anyone know if the transmission from a 6.0 (2003) will fit my 7.3 (2000)?
If you have experience with something like this any advice will be much appreciated.
Thanks!
Just so you know what level I am at; I have owned an auto body/mechanic shop for 33 years and have extreme experience in rebuilding/modifying all types of vehicles. I have never attempted this conversion, however, and figured I would come on here for some advice.
johnnyboss is offline
post #2 of 2 Old 08-27-2011, 01:18 AM
dazdillenger's Avatar
Feedback Score: 7 reviews
The 6.0 transmission will not directly swap (which is a real shame as the 5r110w used in the 6.0 is superior, and is the same for both 2 and 4wd applications!)-at the very least you would need a PCS stand-alone controller and tuning for the trans. As for the 4x4 conversion, it is very simple (minus the transmission, which you either need to replace the output shaft/case, or use a 4x4 trans). The frames are identical, all the holes are already there-the 4 rivets that hold each spring bucket in double as the 4x4 upper shock mounts. You need the complete front differential (make sure to get one with a gear ratio that matches your rear), leaf springs, fore and aft leaf spring hangers, pitman arm, track bar backet, transfer case (they have a different input shaft spline pattern for auto vs manual transmission), and driveshafts. If you decide to get a manual transfer case (np271), the swap is VERY simple. The np273 is much, much more complex if you want the ESOF to function properly. I prefer manaul transfer cases anyway.
The 05-up suspension is a better choice. You re-use your coil spring buckets-and the turning radius is superior by far!
2005 Lariat CCSB F-350 SRW
300,000 miles and going strong
Exterior
12" fabtech lift with 40" Xterrain's on M/T classic locks, Adjustable track bar, Bilstein 7100 reservoir shocks
Performance
Edge juice/attitude CTS, SCT with ID tunes, Snow meth. injection, Diamond eye 4" exhaust, 03 turbo, ARP studs, Sinister coolant filter
Interior
2010 stone seats/console, pioneer avic d3 with backup camera/bluetooth
Misc.
Viair 450c compressor, dual 2.5 gallon tanks, air horns rated @115db
dazdillenger is offline
Tags
conversion , f350 , transmission
