Boost leak fixed today - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-21-2011, 10:16 AM Thread Starter
Quoted: 3 Post(s)
So I have been a little concerned with how fast my EGT's were climbing under full throttle lately. Under normal driving conditions they were fine,usually around 450-500 crusin at 60mph. But under WOT it would only take less than 5 seconds to shoot up to 1000, too nervous to keep them climbing. So today went to home depot and got some 3 inch pvc cap and a shut off valve, threaded the cap and screwed in the shut off valve and a compressor fitting in sequence. Took a couple tries to get it to work, blew off my intake boot going into the turbo first, then tracked down my leak to the little red hose going into the solenoid valve connections on the x pipe. Wouldn't even build past 12 psi with it leaking out of there big time. So now I'm gonna go take a test drive, just had to come inside for a minute, Its like 100 out there!
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #2 of 7 Old 08-21-2011, 10:31 AM
Other vehicle is an F250
Hank's Avatar
Let us know how it works. Pics would be cool too!
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #3 of 7 Old 08-21-2011, 10:35 AM Thread Starter
Quoted: 3 Post(s)
Pics of the my home brew boost leak piece?
2000 DRW CC 7.3
post #4 of 7 Old 08-21-2011, 10:47 AM Thread Starter
Quoted: 3 Post(s)
here is the boost leak detector
2000 DRW CC 7.3
post #5 of 7 Old 08-21-2011, 10:49 AM Thread Starter
Quoted: 3 Post(s)
just kept an eye on the boost gauge in the cab, then walked around and hit the shut off valve and popped off my compressor hose so I could keep the compressor running and hook back up to add more air to keep tracking down leaks. I only had one but it was flowing real good.
2000 DRW CC 7.3
post #6 of 7 Old 08-21-2011, 10:40 PM
Quoted: 14 Post(s)
What did you clamp it to? Into the intake boot in place of the air filter?
ttyR2 is offline
post #7 of 7 Old 08-22-2011, 05:13 AM Thread Starter
Quoted: 3 Post(s)
I clamped it to the intake boot coming off the turbo
2000 DRW CC 7.3
