Hey guys; I've got a 2000 F350 crew cab. I drive 58 miles round trip to work and back. I cruise at 60mph all the way on cruise control and the RPM's are around 1400 to 1500 max getting about 16 miles per gallon. My question is, should I gear down so I run a higher RPM? I believe I have stock gears (3.73) What is the optimal RPM's for cruising 60mph? I would like to get close to 20mpg if I can. Oh, almost forgot: I have a tymar intake, 4" turbo back exhaust with muffler delete, and Edge Evolution programmer set @ 80 horse, Trans., Pyro, and boost gauge. The boost runs at about 4 psi at 60mph, if I gear lower would it get the boost up and get better mpg? Thanks for all you help, this site is AWESOME!!!!!!
I usually run at 1900 on trips which is 70mph and I get 19mpg. I would think that more rpm and more boost would use more fuel.
stick with the 3.73's going up to 4.10s will use more fuel
When I travel I cruise at a constant 68mph which is barely over 1900rpms and I get 19+ through hills in TN and VA and 21+ on flat land like in TX.
i think that if you raise the RPM's you will use more fuel. i may be wrong but thats my opinion!!!! man 58 miles round trip....whew!
Thanks guys! yeah, I've been doing the same round trip to work and back for over 10 yrs now. I usually have a smaller car that gets good gas mileage but now I have this great powerstroke and I won't drive anything else. Just trying to get the best MPG's I can. I work in Portland, Or. but don't like the city crowds so we live out in the country.
Every vehicle has an optimum rpm to speed ratio and Im pretty sure its 1800-1900rpms for our trucks. Meaning whichever speed that is at is the peak of good mileage while going the fastest before engine speed is detrimental to mileage.
My ol beast has 4.10's and I run about 2,000 on the tach at 60-65 and get around 18-18.5 going back and forth to work. WE jsut got back from a trip to the Outer Banks and South Carolina and we got around 19-20 most of that trip running 70-75 most of the time. It all depends on the truck I guess...lol
I'm jealous--58 miles roundtrip. I drive 62 miles one way! Every day.
I have 3.73's in mine and i'm at 2000 rpms at 70 mph. With my mods, I get almost 20 MPG. I think the best way to get the best milage is like I was told, Keep your boost under 5 lbs. and keep your EGT's about 700, no matter what gear or speed, that will give you the best milage. |
For fuel Mileage you would want to go to 3.55:1 gear ratio. That will lower your engine speed while cruising but you will loose acceleration if you do that. I suggest you turn your edge down to give you more mpg.
