Trying to understand coolant requirements for diesel engines
So what is so special about diesel engines vs. gas engines as far as coolant goes? Does the water pump move enough water to fill the Hoover dam or something? Is there a reason I don't want to use the ELC that Toyota sells and that I use in my 4runner? Good to something like 150,000 miles between changes. The engine is iron and aluminum. What is in a 7.3L diesel that would make it need something different?
Just looking to learn what's unique about diesels. Found this. Is what they are saying relevant to our engines? http://flashoffroad.com/Maintenance/...antifreeze.htm Last edited by ttyR2; 08-15-2011 at 09:36 PM. |
I did a search and there is alot of info on this subject. Im getting ready to change my coolant in my truck with something better. Btw i own a couple 4-runners
Cylinder pitting and cavitation are the biggest problems with respect to coolant facing the 7.3. You can run MC green (for 15-30k), MC gold (or Zerex G-05) for 5 years and 50-150k or ELCs for 3-8 years and 300k-1000k. I am running Valvoline Zerex G-05 with no problems. |
What's different about a diesel has to do with the 'knock' produced when the cylinder fires
This powerful force can produce tiny bubbles on the Outside of the steel cylinder sleeve (the coolant side not the piston side) and is the source of the cavitation you read about Over time, these cavitation bubbles will damage the steel sleeve (just like the pitting you see on a boats prop) and can actually pierce the the cylinder wall Coolant is NOT the place to ''cheap-out'' on a diesel
For the best coolant use a true ELC that meets the strict EC-1 rating. Just don't grab a jug because it says ELC on it. You need to look to make sure it meets the strict EC-1 rating. You also don't buy coolant because of the color, the color means nothing, again, read and make the right choice. Fleetrite's ELC , which is the same as Rotella's is good for 300K and out to 600K if the extender is used at 300K. All of this without checking the SCA level.
Of course I would never live any fluid in my truck for that long, but it is good to know I can. Make sure you only buy the concentrate and not the 50/50 mix. You will also need 24 gallons of distilled water, see the manager of your local grocery store, mine gave it to me for .50 per gal. Do a proper flush n fill, this is very critical, this is also a good time to add a coolant filter and to switch the upper rad hose to one from a dual alt set up that goes around the fan belt instead of through it. I have posted the " how to" on proper flush n fill multiple times. If you can't find it PM me. |
