soygold bio-diesel - Ford Powerstroke Diesel Forum
Old 06-10-2006, 03:46 PM
soygold bio-diesel
i fillally bought my first tank of bd. it was $2.99 in phx. i must say i did hear when it started running through the motor. it quited down a tremendously. i like that. i didnt notice any power lose. i did notice i big differance in smoke. alot less i didnt like that. i havent used it long enough to check mileage but i will.so far i like it but i have to drive 25 miles to get it. how many of you are running bd and how do you like?
Old 06-10-2006, 06:36 PM
PIPE HITTER
I picked up some B100 not too long ago, just about 3/4 of a tank I noticed the truck being a bit quieter as well. As far as MPG's go, no change really, as near as I can tell. Smoke was less for sure. I would not mond running some more through the truck, the only problem is the Bio station is about 30 mins. from here. They are supposed to open one within about 10 miles of me at the first of July, once I run some in back to back tanks, I can comment a bit more. But so far at $2.59/gal I like it.
Old 06-10-2006, 07:34 PM
Send a message via AIM to dgramenz Send a message via MSN to dgramenz
I've been running soydiesel for a little while in my truck and love it. I think the blend is either B11 or B15. The engine clatters less and seems to have a little more power and lugs better. I haven't noticed much about smoke, but mine didn't make enough in the first place. Even if it did, I'd still buy it. Anything to boost demand for soybeans!! That and it's about $0.16 cheaper than regular diesel is here because of a state tax break for diesel over 10%....
Old 06-10-2006, 08:21 PM
we have b100 here i realy like it so far but for me it a little drive but if it helps it helps the enviroment and my engine it might be worth it.
Old 06-11-2006, 02:30 AM
biodiesel
AZ2001, I am also in the east valley of Phx Az. where are you finding the biodiesel Ive looked and am not having any luck finding any?.
Old 06-11-2006, 04:59 PM
the only place i found to buy bd at the pump is western state fuels on 16th ave. and grant 2.99 a gal 602-252-4011
Old 06-11-2006, 08:43 PM
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Anyone know what causes it to produce less noise and smoke? Also what does it smell like?
Old 06-11-2006, 09:05 PM
biodiesel makes the engine quieter because it has very good lubricative properties....better than sulfur. it makes less smoke because the bio part (usually soybean oil) burns very clean and easily because of high cetane. and the smell is the best part....in higher blends, you're exhaust will smell a little like french fries
Old 06-11-2006, 09:06 PM
the way i understand it more lubricity less hydrocarbons no sulfer and this kind smell like remote control air plane nitro fuel and soybeans. it does not smell like petro diesel at all.
Old 06-11-2006, 11:50 PM
I manufature my oen Bio-Desel, and have noticed a little a little MGG difference, the key is to monitore your filture in the terms of water and filter capicty.
