Leaving #11's on the road??? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 08-15-2007, 07:40 PM Thread Starter
HardLuck Case of the Year
Ditty's Avatar
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
OK...so Tuesday night the g/f and I went out to Open Mic Night so I could play and she could have a few drinks. On the way home, SHE asked me to do a bit of a burnout. SO, I get to an area that is clear of houses and whatnot and rev up to 2500 and drop the clutch. Lots of wheel spin but ZERO #11 on the road...and ZERO smoke from the 35" BFG A/T's. SO I try again, this time giving a little bit of brake to keep the truck stationary while I'm spinning 'em. Still...a VERY faint #11 on the road.
SO, how are you 6 spd manual guys getting good #11's??? I tried about 5 times and got minimal results.
DITTY
Brisco:-White 2000 F-350 PSD CrewCab/SRW/LongBed/4x4/6spd Manual/HUGE Powerstroke.Org Vinals!
Favorite Mods: Baby-seat mod/Girlfriend delete/6pos on Xtreme!
Repairs since bought: both batteries/alternator/3 transmissions/4 clutches/entire front axle/new steering stabilizer/power steering pump
Still broken: cracked windshield/all glowplugs/glowplug relay/4WD still out/trailer harness no power
Current Best: 16.149@84.13MPH (Est.7800lbs)
Ditty is offline
post #2 of 22 Old 08-15-2007, 07:50 PM
dustindiesel's Avatar
haha #11..i like that
2003 psd 6.0
red crewcab
16" suspension lift, 48" michelin xml's on 20x10 black rockstars, 6000k hid's, crossover steering, zoodad mod, ccv mod, modified up pipe to delete egr cooler,high idle mod, mbrp 3.5 downpipe, train horns(also on remote), diamond plate tool box, recon smoked cablights, Code670 alarm/remote start,100w reverse lights, oil-based underbody paint
**soon to purchase SCT rockwell 2.5 ton frt/rear
-8,520lbs with me in it
dustindiesel is offline
post #3 of 22 Old 08-15-2007, 07:51 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
I like leaving #1111 now thats says something. Sorry Ditty just had to go there. Had a hard time doing it in the mustang at first. It just comes with doing it alot. However you don't want to do it too much tires are expensive. I would say stand on the brake just a little longer to get the tires smokin a bit more and that should do the trick. Also think about a 2nd gear start.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #4 of 22 Old 08-15-2007, 07:54 PM Thread Starter
Ditty's Avatar
Well, I was giving the brake and I could hear the rear tires slowing down...like the rear brake pressure was too much. I dunno. Maybe I should invest in some stockers for practice.
DITTY
Ditty is offline
post #5 of 22 Old 08-15-2007, 07:58 PM
Don't mind me
Quoted: 3 Post(s)
To much brake and ya kill it to little brake it won't happen. What gear were you starting in?
Josh
post #6 of 22 Old 08-15-2007, 08:00 PM Thread Starter
Ditty's Avatar
1st....I'll try 2nd gear next time.
DITTY
Ditty is offline
post #7 of 22 Old 08-15-2007, 08:03 PM
hugeredford's Avatar
I've got the old drums on the back makes it easier to start in first hit the brakes lightly then full throttle or dump the clutch at 3000 in 2nd that seems to do quite nicely
1995 IDI f350 4x4 8 inch lift new paint stacks:whistle:
It's not leaking oil, it's sweating horsepower.
2005 VW beetle diesel 36000 miles 50 mpg
you should all buy one
2005 f350 6.0 cc lb 4x4 drw lariat. EGR welded on both ends and valve removed--------MONEY PIT
hugeredford is offline
post #8 of 22 Old 08-15-2007, 08:05 PM
Don't mind me
Quoted: 3 Post(s)
How do you leave #11 with a front wheel drive car. That is what I haven't been able to figure out.
Josh
post #9 of 22 Old 08-15-2007, 08:06 PM Thread Starter
Ditty's Avatar
On a FWD it's really easy....Ebrake!!!
DITTY
Ditty is offline
post #10 of 22 Old 08-15-2007, 08:08 PM
Don't mind me
Quoted: 3 Post(s)
Never thought of that. I have always driven rear wheel drive until the wifes Focus and it really needs the tires warmed up.
Josh
