Free beer for life!
I knew you would look at this.
I know, dirty trick. ![]() I want to know what everybody is getting for EGT's at idle, and at highway speeds(70MPH, 2000Rrpm's, no load, no incline). I ask, because my pyro reads about 300 at idle, and about 700-800 on the highway under normal conditions. Sometimes it starts to read higher temps(500-600 at idle, and 900-1000 on the highway UNC). If I take it out, unplug it, and plug it back in, it goes right back to reading the more normal temps. What's up with that?? BTW, I drilled and tapped the drivers side manifold for the probe. Thanks |
Dirty trick!!!
Im 300 at idle and at 65 im 600. Not sure why you would get the inconsistent readings.
Me neither, I thought it was weird that I can unplug it, and it basically resets to the right readings.
This is my first set of gauges --totally stumped? |
Make sure you have a good ground. Other then that if they are new see if you can exchange with a new one.
My Quad Commander does the same thing sometimes. Odd, slightlyhigher than norm readings. Reset, usually works fine. When working right I get same readings as Vital, 300ish @ idle, 500-600ish cruising.
about 300 at idle 500-550 cruising.
Even though you are playing with my emotions ill give you a suggestion....
Check all your connections and ensure they are tight. and have a good connection. |
oh thats not even funny!!!!! thats bad never tease with beer
I know, I know, I don't know what came over me, I won't tease with beer anymore.
Thanks for the replies, Ill check the ground and all connections tomorrow. I feel bad, I already returned the boost gauge and got a new one because it came screwed up from the factory. I hope I can get this thing fixed, I don't want to have to return another one, But I definitly will if I have to($184- gauge!) |
sumone's gonna get in trouble once Stump gets on and see's this
