03 Excursion 4x4 Front Axle Seal Replacement - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-27-2011, 08:55 PM Thread Starter
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 14 Post(s)
Does anyone have, or know where to find a good write up for replacing the front axle seals (inner). I had them done about 9 months ago by a local shop who has worked on my family cars for over 25 years but has closed and is unavailable for family medical issues. I just don't have the 1k the local stealership wants to do the job. They are now leaking (1 qt every couple weeks) from and around the 2 outer dust seals.
I've been given several inconsistent answers from sources that vary from a 1 hour job to a 2 day job. Do the gears have to come out or can I just remove the axles, get the long puller and remove from the outside? I would appreciate any good write ups
Thanks for the help. Anyone in the Lowcountry (SC) area who wants to come help for the day with this job and help install JW Valve Body and Derale Cooler (time allowing) and I would throw in a day of offshore fishing on my boat on any one of my next trips. Usually run offshore 45-60 miles once a month with few buddies to troll for whatever is hungry, drink a few cold ones and enjoy a good cigar. PM me if you have experience doing this and are interested.
Thanks
Matt
384,000
PHP Hydra
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #2 of 3 Old 07-29-2011, 04:11 PM
This is not for the person who has to ask how to do it. I just finished installing new vacuum seals in the front end of my 4x4 F350. This vacuum seal stuff was a first for me, but I've done a lot of other 4x4 work. Besides my garage full of tools, I had to buy a $70 installer tool. That's only half the battle. After doing everything I did, you'd still have to pull the differential (center section), and put it back after you've installed the inner axle seals.
The inner axle seals are installed and removed from inside the differential housing. You CAN'T install or remove from outside. I installed these seals on my '98 Dodge one ton but it too had a Dana axle so they'd be the same.
To aswer one of your questions. The first side I did (d.s.) took about 6 hours (learning curve) and getting it jacked up. The p.s. took a good 4 hours. Don't try to do this without that $70 installer tool. You'll only waist a $40 seal (each side). On top of all this you'll most likely need to purchase an installer tool for the inner axle seals. Too bad that we are on opposite ends of the country, I'd help you. If you do it yourself Best of Luck.
02 F350 CC 7.3 PS, auto, 6x6, 4.10 gears LB. AFE stage 2 intake, 4" AFE SS exh, 6.0 atf cooler, DP tuner with five stages
Eng Temp gauge, EGT guage and Trans temp gauge. J.Woods valve body ATS turbo housing. Cooling sys filter & waterless coolant. NON WORKING POS FASS fuel filter sys. Brightbox headlites. I don't care what they say "There's no replacement for displacement."
Don't believe statements about anything being better than a 7.3
GOD BLESS AMERICA!!!!
Bart_3500 is offline
post #3 of 3 Old 07-29-2011, 08:42 PM
jasons 7.3 powerstroke's Avatar
here something i found, hope this helps bud.
Front inner axle seal replacement - Ford Truck Enthusiasts Forums
96 f250 4x4 zf5 trans. 6637 air filter mod.
jasons 7.3 powerstroke is offline
