Where does fuel/water drain tube hang?
I'm looking for the end of the fuel/water drain tube. I have a 2000 F350 7.3. I can see where the tube dissapears into the valley. I thought it exited on the passenger side. I've looked (under the truck) on both sides starting around the starter and going back
. I was looking for an aluminum tube like on top. I have not felt around on top of the transmission yet. I wanted to add more hose so I could drain into a bottle. Thanks for the help. Rick
It should exit right behind the alternator.
Ohhh. I was too far back. Thanks for the info.
Found it
. On my 2000 F350, its on the passenger side, its a copper color not aluminum, sort of behind the water pump area and hidden behind other hoses and wires. I added a length of fuel hose to it so I can dump it into a jar. The hose is held out of the way by a loose tie strap when not in use. Yea, its these little things that make me happy .
That's a pretty good idea.
