do shifter knobs screw on?
anyone else with a powerstroke ever change your shifter knob? i tried to put a hurst t handle on mine today and it didnt want to come off. i already have my stock shifter knob jacked up from wrenching on it but i thot i would ask you guys before i broke it off. i just wanted to know if it was threaded on or like glued on? thanks
it is a "press fit" kinda deal. It's funny yours won't come off. both PSD's i've had after a while will just slip right off.
If it's like my 97 it's splined and not threaded. Cute little ford trick. Knob needs to come straight off, not unthreaded. Prolly glued on too.
thats good lol now mine is jacked up and i cant screw another one on! o well should i leave it on or take it off and glue another on? i think the guy before have glued it on thatswhy i couldnt get it off cuz there was glue around the bottom. dang it!
If the hurst has threads then it won't work. Ya have to get one for a splined shifter rod. I don't know if they make both types or not. If your not dead set on the t-handle there are other companys that make knobs for your application. One is Welcome to www.flameball.com And i'm sure there is more.
If you going to put on an aftermarket knob, you have to use like aflathead screw driver and a hammer. Just put the screwdriver at the base, pointing up, and tap it a few times, the stock knob should pop off.
As for the aftermarket knob, you need one that uses setscrews to fit. Any knob that screws on will not work. |
yup I had to do the same mine was jacked and had to go with a set screw style skull head ....lol
I was told I have to buy the whole shifter from Fords I cant just buy the shifter knob itself
