235hp Powerstroke... - Ford Powerstroke Diesel Forum
Old 08-12-2007, 07:31 AM
Send a message via AIM to CamTom12
So, when I took my valvecovers off to check my wiring harnesses I noticed that my motor was rated at 235hp @ 2600rpm. I thought this was normal until I went and talked to a guy that REALLY knows his powerstrokes the other day... He says most all of the superduty's were 250hp, and that he's only seen 4-5 of the 235hp motors. Apparently there's no mechanical difference between the two, so what do I have to do to make my motor the same as a 250hp motor as a starting point for power mods?
Old 08-12-2007, 07:40 AM
Just get an exhaust and a giood chip and you should be way over 250 horse. You shouldnt have to do anything different.
The Fat Mod
I would just say do the normal mods and not worry about it too much. Any truck can vary from any other truck sitting in a parking lot in stock trim. I say mod and forget
Old 08-12-2007, 08:57 AM
Nice stacks, Logan
I was just asking because if it's only a programming thing then maybe I can get Ford to flash a 250hp tune in before I start modding so I'm adding on top of that instead of trying to reach it
Old 08-12-2007, 10:06 AM
Dieselis' Maximus
If you get a chip your gonna be wasting money for ford to reflash your computer.
Old 08-12-2007, 10:25 AM
I think the trucks that came with the zf 6spd like mine were rated at 235 hp. The automatic trucks were 250hp, maybe because the auto takes more hp to operate than the std???? Get a good 4" turbo back exhaust, severe duty intake, and a chip from dp tuner then forget about what's on the valve cover. That's what I did, couldn't be happier.
Old 08-12-2007, 10:51 AM
I've got a straight pipe now in place of the muffler and an S&B intake, next step is a return-style fuel system and an HPO cross-over. Next step after that is a chip and then a 4" turbo-back
Sounds like I don't need to worry about the valvecover, haha. Thanks guys!
Just curious, what's the ZF stand for?
Old 08-16-2007, 01:57 PM
ZF is the division of Ford Motor Company that builds their transmissions and transaxles.
Old 08-18-2007, 03:05 AM
Ah, cool... Didn't know that!
Old 08-18-2007, 04:10 AM
my dad's 00 powerstroke is rated at 235hp too. ive never seen one of the 250hp motors. wonder if its a northern thing or somthing?
